Install Warn Elite front bumper
from2hito4lo.com
2018 JLUR, 2013 JKUR
Anybody install Warn's elite front bumper (full)? Keeping factory fog lights and we're gonna have to cut the ears on the housing and go find some bolts to make it work. Seems a little ridiculous. Is there something we're missing? Looked everywhere in the box. Why shouldn't it bolt straight up with factory lights? Don't know what else we'll encounter yet. Thought Warn was better than this.
mwilk012
2018 Ocean Blue JLU Rubicon
Service
It's because there are 3 different mounting configurations for the JL fog lights, first depending on whether they are LED or not, and then LED's mounted in the OEM steel bumper vs the plastic bumper are also different. What do the mounting holes on the bumper look like?
LeoD
Leo
Kailua Kona, HI
2018 Wrangler JLU Rubicon
Real Estate Sales
I have the same question, I have the Rubicon plastic bumper with the LED lights.
mwilk012
Service
Would be nice to know what lights OP is trying to fit up, I spoke with Warn's customer service and they didn't seem to really know what I was talking about, and said that all OEM fog lights should mount up. Would really like for someone else to be the guinea pig.
@OUTDOORTREE
Bob
Yakima, WA USA
2018 Rubicon JLU
I had my dealer instal my elite full width bumper on the JLUR. I had plastic oem bumpers with LED light group. Service tech said he had to trim the LED light housing - probably same thing OP is saying.
Jeep Wrangler JL Install Warn Elite front bumper 2FBC2F9D-7B0F-4A0B-9227-2555E5521272
From 2HI to 4LO
from2hito4lo.com
Yes, that's what we had to do. Didn't realize there were different configurations for the plastic/steel stock bumpers. Just make sure you trim the right side when you do!!
dudemind
Los Angeles, CA
2018 Wrangler JL Rubicon
For those who had to trim: how stable do you reckon it is with just the two attachment points on one side? With the steel bumper fog lights, there's at least a substantial plastic mounting "plate" that I'm sure provides some stability. I'm worried that with either of the other fog lights, the thinner plastic would eventually crack if it allows the fog light to gently vibrate/rock back and forth. Want to pull the trigger on this bumper but Warn only gave me a generic, "We're not aware of any issues" response. I've got the LED fogs from the factory plastic bumper...
davidschmaus
Dayton, Ohio
2018 Wrangler JL Sport S
I did the install and for now left the fog lights out. I ordered the Kchilites LED fogs in amber and will make those work
achaffee86
Adam
San Francisco
I'm installing this now and am extremely frustrated. For those of you that completed the install ease help keep out.
I had a plastic bumper and am following those directions. First question is how did you route the wiring harness for the fog lights?
Second question: How did you install the frame doubler plate? It says put in bolts but never references nuts or torquing them down.
Third question: Where the hell is the frame support gussets? The step says to remove two nuts holding the frame support gussets. The picture makes no sense to me.
Fourth question: Did you trim both sides of your frame rails to fit a zeon winch?
Please help!
WestKY
Jerry
Benton,KY
F150 4x4, Jl 2Dr Sport Granite Cyrstal Metallic
Yes OEM halogen fogs will need trimming, also on a note here if your planning on installing Xeon winch the frame rails has to be trimmed also the other winches fit without trimming. Neither was a big deal. I used a small grinder with Cutoff wheel.
treillw
Montana
Jeep Grand Cherokee
Any able to chime in on what I might be doing wrong with these brackets for my 2022 JLURD w/ factory plastic bumper. The LED fogs are going into the full width elite warn and I can't get the lights to be level with the provided holes. Am I missing something, or are the brackets wrong?
Jeep Wrangler JL Install Warn Elite front bumper 20220513_213514
Jeep Wrangler JL Install Warn Elite front bumper 20220513_213549
Jeep Wrangler JL Install Warn Elite front bumper 20220513_213612
