RustyShackleford2022
- Rusty
- Jul 28, 2023
- Florida, USA
- 2022 Jeep Wrangler Rubicon
First post! I custom-ordered a 2022 Wrangler Rubicon and I love it to death. It has been quite a learning curve though trying to understand the wiring compared to my 2007 mustang.
The impetus for this post is that I live in an apartment complex where there have been a lot of break-ins and car thefts. I would like to install a kill switch connected to the starter motor system. I would like the kill switch to operate such that you have to hold it to the ON position while the car is starting (and the computer is continuing to signal the starter motor to crank) and then you can let go (back to OFF) once the car is running. The reason for this is that I want to avoid a traditional on/off kill switch in the ignition system setup where I have to remember to re-engage it every time I leave the car. If modern cars work like my 2007 mustang did, the command/signal to the starter to run would only be needed while the engine is running, so it would be okay for the wire carrying that command to be disconnected once the car is running.
Based on what I am seeing, my first guess was that I would put my switch on the BN/BG wire coming out of the left side of the Body Control Module in the picture below. I have located the BCM module and the wire but now I am having my doubts. From the diagram it looks like this wire sends the signal to the Stop/Start Relay which also is connected to the relay for the starter solenoid. However, if you click the link above you can see there are quite a few other systems also connected to this. This makes me pretty sure that it would not be good, or maybe even possible, to have this wire in a setup where it is OFF by default while the engine is running as the other systems would be disconnected when the switch goes back to off after the engine starts.
My question is, if that is not the signal wire that tells the starter motor to run, which is it? Surely there is an isolated wire that does not connect to the other systems with the sole purpose of sending the signal to run the starter motor?
My other thought would be to tap into one of the YE/GY wires immediately to the left of the Body Control Module in the linked above diagram. However, I would prefer not to, as I think those are the actual power wires to run the starter, which would be high amperage. I would rather tap into the low voltage/low amperage signal wire if that is an option.
Any advice or thoughts would be much appreciated.
