identify my differential?
Pinion
Rob
Hull, MA
1971 FJ40, 22 Rubicon Unlimited
Project Manager
That’s a D35. Aka M200.
This is a D44 (aka M220)- note the rectangle that the fill plug exists on is larger:
And there’s this too-
Edit: I should clarify that what we commonly refer to as D35 or M200 and D44 or M220 aren’t technically the same axles. The M___ axles were released with the JL.
This is a better picture. The original looked to me like the bottom of the housing was flat and the left side might have been straight.
Jeepboy420
Winkle
Ontario, Canada
2022 JL Wrangler 2 door Sports
I have a 2022 wrangler unlimited Sahara,.
See attached picture
Can anyone tell me what it is?
I'm a complete Jeep newbie so I'm trying to learn about it.
Does your differentials comes with drain plug?
Cat22
Cat22
Olympia, WA
2022 Wrangler Sahara Unlimited
Well, as you can see it has a fill plug but I do not know if it has a drain plug or if the cover has to come off to be removed. It's the rainy season here now and I'm getting a bit old to crawl under it and check. The next oil change, I will try to remember to look.
Jeepboy420
Winkle
Ontario, Canada
Yes i found out this morning when i was going to service diffs. None of diffs has drain plug and i have a 2022 sports.
