HVAC VENTS HISSING
FL1P
Fl1P
Metro Detroit
'18 JLU Rubicon
2018 JLU RUBICON WITH DUAL CLIMATE CONTROL
I'M AT A LOSS. WHEN THE HVAC FAN SPEED IS TURNED TO 4 or HIGHER, I GET A HISSING SOUND COMING ONLY FROM ALL 4 DASH VENTS. 1-3 SPEEDS, NO NOISE.
I'VE CHECKED EVERY POSSIBLE CONFIGURATION I CAN THINK OF TO NARROW DOWN WHERE THE ISSUE IS COMING FROM.:
-INSIDE THE CAB ONLY, NO NOISE FROM THE ENGINE BAY
-NO VISABLE SIGNS OF AC LEAK IN THE ENIGINE BAY
-NO HISSING FROM THE FAN MOTOR ITSELF
-ALL MODES: HEATER, AC, DEFROSTER, HOT or COLD, IT MAKES THE HISSING SOUND
-CABIN FILTER WAS REPLACE 2 MONTHS AGO and NO OBSTRUCTIONS FROM THE FILTER
-CONSISTANT HISSING SOUND DOES NOT GET LOUDER or FASTER AS FAN SPEED INCREASES
-THE AC DOESN'T SEEM TO GET COLD EITHER
-TEMPERATURE SEEMS TO ADJUST FROM HOT TO COLD(OUTSIDE AIR TEMP) BUT ITS HARD TO TELL IF ITS ADJUSTING THRUOUGH THE MID RANGE TEMPS or JUST HOT ON and HOT OFF
ANY THOUGHTS ON WHAT IT COULD BE?
THANKS
FL1P
FL1P
Fl1P
Metro Detroit
'18 JLU Rubicon
I was hoping to get some kinda off response before taking it into the dealer but...
Turns out there was a hole in the condenser which leaked all the Freon out of the system. $1400 later, everything seems to be back to normal.
jc1003
Jorge
Frisco Texas
2022 Sahara, 2025 Ram 1500, 2026 Hyundai Tucson Hybrid, 2023 Hornet
IT
Expensive!!!!
EtBiart
ET
Long Island, NY
Jeep Wrangler Unlimited Rubicon
Aircraft mechanic
Were you under warranty? I’m having this same issue. I have a maximum care warranty which covers air/cooling but I’m hoping for no surprises.
FL1P
FL1P
Fl1P
Metro Detroit
'18 JLU Rubicon
Unfortunately it was not under warranty as that expired years ago. Turned out to be a leaking AC condenser up by the radiator. Tough pill to swallow but the dealer charged me $1391.50. So at least the AC system was refreshed but then I was hit head on a month later and my Jeep was totaled. 😢 Ended up getting a '21 Rubicon to replace my '18.
Flip
Johnny
Virginia
2023 Jeep Wrangler Sport
Retired Power Plant Engineer
I'M AT A LOSS TOO.
mwilk012
Oklahoma
2018 Ocean Blue JLU Rubicon
Service
The noise is Freon flowing through the expansion valve. It makes sound because it is low on Freon.
Flip
Johnny
Virginia
THANKS
DID YOU EVER GET IT FIGURED OUT BUDDY?
