Pneumatic hissing noise when shifting
Cat4
Jake
Washington
2022 392 XR
I’ve noticed a pneumatic/hissing/scratchy noise, almost sounds like a turbo blow off, about a second before my Jeep shifts from 1st to 2nd. Typically happens when the Jeep is hot and starting from a stop and medium throttle. I don’t think it happens when I accelerate hard but not sure as it may get drowned out by the engine. Doesn’t happen all the time. 3.6 etorque, auto. I had the same issue on my 2020 JT which was ultimately a lemon for other reasons. Any thoughts?
mwilk012
Oklahoma
2018 Ocean Blue JLU Rubicon
Service
Are you sure you aren't hearing the vacuum pump/brake booster?
jessedacri
Jesse
Lake Arrowhead, CA
2019 Bright White 2dr JL Rubicon 3.6
I think you might be hearing the same thing I posted about a while back:
https://www.jlwranglerforums.com/fo...or-whine-noise-accelerating-in-1st-2nd.43165/
If you listen to this TrailRecon video at the 10:15 mark you can hear what I'm describing faintly as the yellow Jeep goes by:
Is this it? If so, I've never found an explanation other than it's normal for the 850RE transmission and most people just aren't hearing it, I guess.
Cat4
Jake
Washington
2022 392 XR
Don’t believe so as the noise is not tied to the brakes at all, but could be wrong. I thought brake booster noise happened when you hit the brake.
Cat4
Jake
Washington
2022 392 XR
Hard to tell from the video but I wouldn’t describe it as a whine. It’s a single event, almost like releasing air from a pressurized tank. Lasts about a second and just before it shifts.
mwilk012
Oklahoma
Service
Would you recognize the sound of the vacuum pump if that is what it was?
mwilk012
Oklahoma
Service
Yea, sit there with the windows down in park and press the brakes a few times. Listen to the hiss when it kicks on.
Cat4
Jake
Washington
2022 392 XR
Confirmed, not the brake booster…
Cat4
Jake
Washington
2022 392 XR
Bump. Any thoughts?
