How bad is this?
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
Sorry, I screwed up my highs and lows...senior / newbie moment...I do 4 high when I exercise it, NOT 4 low...thanks for the reply and helping me catch my error!
No reason to turn in 4 hi on dry pavement either. There's no center diff, so front and rear is forced to turn at the same speed and causes some binding when the front and rear follow a different line in a turn.
richk225
Rich
New Jersey
2021 392Rubicon XR 2017 Jeep Grand Cherokee
retired due to broken back
If you want to bind it up real quick, just open the door while in reverse. Seriously don`t
J.Ferreira
Castle Rock, Colorado
www.tmgps.org
1999 Jeep XJ
Whew, ok, thanks.....It has no issues at all, I just always heard that you couldn't run in 4WD above like 45 mph....
I noticed it when I went to turn into a parking spot and the tires acted weird....
You can shift on the fly into 4H in the JL up to 55mph per the manual, so 45 certainly isn't anything to worry about.
dragoneggs
Seabeck, WA
'22 Snazzberry Pearl JLR
I’m a believer in ‘exercising’ your Jeep. But it is best to do it off pavement. But do do it. Because when you need it, it will be there for you.
J.Ferreira
www.tmgps.org
1999 Jeep XJ
Yeppp
I exercised my transfer case lever a few times before winter last year, and now if I need to switch to 4H quickly for inclement weather, it's very easy and very ready for me.
richk225
Rich
New Jersey
Yeppp
It's A good idea to go through its paces every now and then, a little oil circulating isn't a bad idea
I have made the mistake in the past of not testing or trying out locking hubs, gear selector and see that you can get neutral
Every few months I just try almost everything (not that there's a lot) just to avoid any issues
Shibadog
Bowling Green, Ky
2020 Wrangler Sport S hardtop
In general, you do not want to use 4 low on dry pavement, you definitely do not want to turn in 4 low on dry pavement.
If you want to "exercise" it, you can drop it in and drive a few feet in a straight line.
This. If you try and turn on dry pavement you WILL feel it struggling. That is NOT good on your Jeep!
Wraif
Kevin
New Jersey
19 2-door manual Rubicon, 09 JKU, 23 JT Overland
I can open the door and drive in reverse, no problem. Oooooh, that right. You got an automatic
