How bad is this?
NAZJeeper
Woody
Northern Arizona
2015 JK
So I was heading into town to Sam's Club and decided to run off-road for a few minutes (State Land is right next to my house). So I threw it in 4WD and had a little fun in the sand. But..........I left it in 4WD and hit the road.......20 minutes to the store on a freeway.
So how screwed am I?
AcesandEights
Aces
So. Oregon
2024 Toyota 4Runner
No harm, no foul.
Dusty Dude
Colorado Springs, CO
1970 Ply Roadrunner, 2010 Challenger SRT
As long as you weren’t doing any tight turns in a parking lot all afternoon, you’re good.
NAZJeeper
NAZJeeper
Woody
Northern Arizona
2015 JK
Whew, ok, thanks.....It has no issues at all, I just always heard that you couldn't run in 4WD above like 45 mph....
I noticed it when I went to turn into a parking spot and the tires acted weird....
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
Normally shouldn’t SHIFT to 4wd above 45. You can run faster once you’re in.
BLS65
Bret
Saint Johns, Florida
, 2000 TJ, 77 CJ7, 2024 JLU Willys, 2025 Gladiator Rubicon X
Business Development Manager.
If you are having a hard time getting back into 2H your drive line is bound, back up in a straight line for a short distance to unbind (take the load off the drive line) and it should slide right back into 2H
Dusty Dude
You can run part time 4WD above 45 mph, it just isn’t considered safe in adverse conditions. Any turning of the wheel can cause a loss of steering because the inside front wheel will spin/slip, and then you are only steering with one wheel.
You were feeling that effect when you were turning in the parking lot. The inside wheel was trying to go the same speed as the outside wheel causing your drivetrain to bind. The wheel finally spun on the pavement, releasing the binding and making your Jeep lurch around. Then the cycle repeats.
Old Jeeper
Don
US Army Infantry, IT Engineer
99% ok, but don't make a habit of it, especially at FREEWAY SPEEDS on dry pavement!
NWJeepr
Twin Peaks
2025 Wrangler 2-door
Another vote for "you're fine".
It's harder on the driveline than having it in 2wd and not something you want to repeat if you can avoid it. But hey, we all learn.
Robertyoke
Robert
2019 jeep wrangler jlu rubicon
Yeah in low range
RajTaj
Southern California Desert
2019 JL Wrangler Sport 2-door
Not trying to hijack the thread, but related question:
I "exercise" my wife's 2019 JL Sport in 4WD low only on dry pavement around our neighborhood once a month as it was my understanding that this helped make it easier to shift the transfer case, and help keep the relevant moving pieces of the system lubed up. Never go above 45 and never do 4 high mode.
I'm ok doing this, right? Is it necessary?
BTW, thanks for the answers to OP question, this was a concern of mine too.
GATORB8
CLT NC
In general, you do not want to use 4 low on dry pavement, you definitely do not want to turn in 4 low on dry pavement.
If you want to "exercise" it, you can drop it in and drive a few feet in a straight line.
RajTaj
Sorry, I screwed up my highs and lows...senior / newbie moment...I do 4 high when I exercise it, NOT 4 low...thanks for the reply and helping me catch my error!
