Homelink programming problem
Dalma
Dale
Vancouver Canada
2019 Jeep Rubicon - Bikini Pearl
My apartment building has a 15 year old garage door and after 6 attempts I have not been able to program my homelink. I have a universal keychain style of remote so I don't think that the codes/frequency it uses should not be supported.
I live in Canada and I have read that means our remote transmitters time out after several seconds. The instructions for Canadian remote linking indicate to press the remote many time, about every 2 seconds while holding the homelink button.
After about 40 seconds the homelink seems to timeout.
Has anyone else encountered and solved this?
GtX
Illinois
2020 JLUR 3.0D
Working for the man.
I had to install additional hardware to make a new garage door work with my 2009 and 2011 vehicles. Perhaps new vehicles are not compatible with older systems without the hardware to translate the signals.
viper88
Nick
IL
Call HomeLink. They have a excellent customer service department that will walk you through the programming procedure on the phone.
dsgrey
2019 JLU
Where is your vehicle parked when you attempt to program? Mine wouldn't program while in the garage and only a few feet away from the opener. I recall reading you must be further away so when I backed out into the driveway, it programmed without issue.
COBoarder
Jamie
Washington DC
2018 JLUS Ocean Blue
Make sure you are using an original door opener to link to Home Link. My old garage door would only connect Home link with an original remote, the replacement keychain opener would never work. Keep at it.
Arterius2
Jerry
Vancouver, BC
2018 JLU Sahara 2.0L
They let you program garage door openers in an apartment building?
JeepCares
Auburn Hills, MI
JL
Hi Dale,
We're sorry to hear about your experience. We recommend reaching out to Canadian Customer Care if additional assistance is needed. I have included a link with their contact information below.
https://www.fcagroup.com/en-US/footer/Pages/contacts.aspx
Alex
JeepCares
Dalma
Dalma
Dale
Vancouver Canada
We are a small self managed building. I have programmed every remote control in the building. If I had direct access to setting the required code I would be done in minutes
