Hints concerning the DEF box
47Jeepster
Tom
Queen Creek, Arizona
2025 JLUR X ... 2023 JLUR Diesel ... 2018 GC Summit
1) Seems that the &$%& nozzle provided with the DEF box has a 50% chance of dribbling down the side of the Jeep or on your feet. To cure that, go down to your local ACE hardware store and buy an o-ring that will fit in the grove in the cap of the nozzle ... Industry #124 down in the right lower corner. Actually, buy two.
Jeep Wrangler JL Hints concerning the DEF box 20250927_163809
Install that in your nozzle and you can pour the DEF drip free.
Jeep Wrangler JL Hints concerning the DEF box 20251019_132544
2) Grab a clean nozzle and install that second o-ring in it. Now save that nozzle for pouring windshield washer fluid in the difficult to fill reservoir. Yep, it fits the standard gallon jug perfectly.
Jeep Wrangler JL Hints concerning the DEF box 20250511_095151
3) If you change your own oil, that empty DEF box becomes extremely valuable. I bought and installed a ValvoMax quick twist oil drain plug ... other brands are available. Slide the DEF box under your Jeep and insert the drain hose in the box to drain 9 qts of messy oil into the 10 qt box. I've drained 180 degree oil into the box with no problems ... that's about as hot as you can stand it to work the quick drain mechanism. Recap the box and take it down to your local O'Reilly's store for disposal. No splashing into the skid plate or out of the drain pan ... in fact, not a drop will go astray.
Jeep Wrangler JL Hints concerning the DEF box 20260627_104957
I let the oil drain a long time with this set up. That helps let the filter cool off, as well as, drain the oil out of the filter. Removing the filter without drips is the last problem to work out. Right now I place a disposable rag under the filter housing and simply let it soak up any drips.
Gomer Pyle
JD
DFW Texas
2021 Sarge JLUD Willys 3.0 EcoDiesel w/SOT, Cold Weather, Alpine and Tow Pkg
very nice...thanks for the DEF box suggestion for waste oil. I have a Fumoto oil valve with drain hose for ease of oil changes. As for the oil filter, if you bust it loose first thing on your oil change and let it drip for 20 min or so almost nothing comes out as it has drained back down into the crankcase. I still keep a 1 gal freezer baggie next to the filter and once unthreaded I quickly drop it into the baggie...and I keep a shop rag below the filter just in case...
Comet
New Orleans, LA
JL Wrangler
Tech
I'd rather just get rid of the Box
Gomer Pyle
JD
DFW Texas
It's so much easier (and significantly cheaper ... and no box) to go to a truck stop and fill up at the pump.
when I'm feelin' cute sometimes I just go to the fuel island at our shop and get DEF from our 3k gal bulk tank...
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
I'd need to be wearing a skirt or something similar to feel cute. I'm not sure I'm up for that right now!
Gomer Pyle
JD
DFW Texas
does this dress make me look fat? 🤪
Camaroboi13
Justin
San Bernardino, CA
2022 JTOD, 2024 JLU W
LEO... life in Chino
I have a problem here because A) the closest def pump is nearly 20 miles from me, and B) I’ve done this multiple times, I don’t get as many miles between fill ups from the pump as I do with the box.
Ratbert
PNW
Software Engineer
Mine is 13 miles away. I just have to remember to fill up when I'm getting low and in that area.
I stupidly neglected to do that this go around though and ended up spending $30 on a damn 2.5 gallon box yesterday. I found out the warnings get stupidly insistent when you get below 100 miles!
I'm not sure how that's possible. They're both standardized under ISO 22241, which is 32.5% automotive-grade urea and 67.5% deionized water. Truck stops have a higher turnover, meaning the DEF is usually fresher and hasn't been sitting on a warehouse / store shelf for months.
That is, as long as you're filling up from a truck stop that sees decent volume, the DEF should be quite a bit better than what comes in a box.
Camaroboi13
Justin
San Bernardino, CA
One would think they would be the same, but it’s been consistently different with each method. I just make it a point to grab a box every time we do a Costco run, they’re usually $13-16 dollars a box there. I probably have one or two in the garage at all times. I’m sure Costco is just like the gas stations, I highly doubt the boxes are sitting around very long before being sold.
Grayhound
Michigan
Jlurd
How much def are you running through. I drive quite a bit but I’m only adding def every month or so. I fill up after I get the 500 mile start up warning next truck stop I’m at. I tend to use the same truck stops around the state due to my fuel discount.
47Jeepster
47Jeepster
Tom
My usage has been running at a steady 750 to 800 miles per gallon ... ~2000 miles per 2.5 gallon box. I use the boxes because my local Tractor Supply sells it at a reasonable price, so there is a good turnover in the product ... I check the manufacturer code. When heading out on a trip, I check all of the fluids and top off the DEF from a box that has been stored in an air conditioned room ... it's hot our here in Arizona.
