Highway bounce, cold weather
Bulletbill
Bulletbill
Tom
Central PA
2021 JLUR
Update:
On the drive home it was 8 degrees warmer and there was a noticeable change in the ride; so chalk it up to cold weather makes the shocks ride harsher? ?‍♂
aldo98229
Aldo
Bellingham, WA
Market Research
Shock performance shouldn’t be affected that much by a change in temperature of a few degrees.
I still believe you got a defective shock absorber.
The Last Cowboy
San Antonio, TX
2020 JL Willys 2 door
It’s not unheard of for a shock to get damaged during transport. Look underneath and see if there are any signs of leakage or damaged bushings.
Bulletbill
Bulletbill
Tom
Central PA
2021 JLUR
I did do a cursory check prior to driving home and everything looked ok. Will jack it up this weekend and give the suspension a more thorough look.
The Last Cowboy
San Antonio, TX
Also, check you radius arm bushings and any other suspension parts for looseness or damage. If you find any, mark it with a silver sharpie or paint pen so the tech at the dealer will see what you saw.
