Cold weather/fob issue
Kalanimal
Long Island, ny
V6 rav4
Hey guys,
For some reason my auto start does not work from the front door of where I just moved to. (Definitely within range). I can't figure out why.
I am wondering if anyone figured out a way for the Uconnect app to start the JL as if it were started with the cold weather option. Basically I can start it so the engine is warming up but it isn't blasting hot air/heated Everything like it does when using the fob
Thanks!
Rhinebeck01
Ormond Beach, Florida
Retired at 55 ..
@Kalanimal
Have you tried with each of your 2 fobs ?
Consider changing the battery in the Fob. Could be an issue related to a depleted battery.
Key Fob battery: CR2450
robaw
Rob
Iowa
Hey guys,
Thanks!
I've remote started several times via fob and app, both activate the hot stuff the same way. Remember it only does that if the outdoor temp is below 38 (or somewhere around there).
Kalanimal
Long Island, ny
V6 rav4
@Kalanimal
Key Fob battery: CR2450[/QU
@Kalanimal
I don't have access to my 2nd fob right now. The remote start works no problem in a parking lot/anywhere else besides my new place.
Kalanimal
Long Island, ny
V6 rav4
Interesting. I'll try thru the app tonight and see if the cold weather options turn on. Thanks!
Paluss
maryland
2022 JLURD
40 and below and will start and turn off if vehicle is low on fuel
BillG
Bill
Middle Tennessee
2018 Sting Gray JLUR / 15 Harley Tri glide / 50 Dodge Rat pickup
You can go in uconnect and turn off all the cold weather stuff, and turn it back on when it turns really cold.
BWWJL
Chicago Area
18 JLU Sport S
Hold key fob touching chin to see if that helps ... turns body into antenna. There might be some weird interference thing going on.
Jruedastinger
Jorge
Palo Alto ca
2018 Jeep jl
What I notice on mine a couple times was that it didn’t start if the battery was low, I have a fridge and I hadn’t start the car in days.
