2019RubiconNY
You think metalcloak will sit higher than the Mopar lift? One shop I know of swears by AEV.The quoted height gains are usually way wrong and you kind of just need to go by photos of similarly equipped rigs with the lift you want. The Mopar 2" is higher than a handful of 2.5" lifts and all of them net quite a bit more than 2" or 2.5" anyways. My advice would probably be avoid lifts quoting 3.5" and 37" tires if you don't want to do lots of additional work and upgrades and instead stick with a 2/2.5" and 35s setup. Plenty high and aggressive looking with not as much change to factory geometry and ride quality.
The difference between a $3k Metalcloak Gamechanger 2.5" and a $1300 Mopar 2" mostly isn't ride height, it's ride quality+performance as well as items included. I'd say both of these lifts net a similar level of lift, but the metalcloak includes beefier control arms with their incredible bushings for an arguably softer ride on road and more flex off road, front and rear track bars to center your axle properly after lift, and dual rate springs that will better compensate for a fully loaded jeep without sagging. They also suggest a front driveshaft but I have not seen a need for that even with lots of off roading. If you go 2.5" and aren't regularly flexing your front axle to the absolute maximum you'll never need an aftermarket front driveshaft. I'm still on my stocker and I wheel it almost every weekend.
All that said, if you're not planning on doing a lot of technical off roading you may not need a $3k lift, but I trust Metalcloak's geometry and engineering to keep my Jeep handling nice at a non-factory ride height, and I've seen their bushings show no sign of wearing out going on three years in some buddy's rigs who wheel the absolute piss out of them.
ugh so many options
And yes this will be daily driven
