Help with wheel selection
Maverrck
George
Rochester
Wrangler JL
Hey guys. Sorry for the same thread every noob posts here. I’ve been reading a few threads about lifts and wheels and offsets. However I don’t see any regarding the Rough Country 2.5” lift.
Bought an 18 JL and was given a RC 2.5” suspension lift (https://www.roughcountry.com/jeep-s...nd=2018-jeep-wrangler-jl-unlimited-4wd-739727). I’m not going off-roading and I believe I don’t have use for any other lifts. Plus these were free so I can’t complain. Strictly looks
Just curious what you guys think about the wheel/tires I’ve selected so far.
18x9 Fuel D569 -12mm Offset, 4.5" Backspace
Thunderer MT Tires - 35x12.50R18
17x9 Mammoth Boulder -6mm Offset, 4.7” Backspace
Mud claw Extreme MT tires - 35x12.50R17
blnewt
New Mexico
Just ask @cosine he knows!
I'd run the 17s, better tire selection and you'll have a bit taller sidewall and slightly less tire poke at the fender.
You may want to consider the Mopar lift LCAs to keep your caster in the 6 degree range. After that lift your Jeep will probably have caster right around 4 degrees which will make it prone to wander at high speeds rather than wanting to track tight & straight. Here's an install post I made about them
https://www.jlwranglerforums.com/forum/threads/rubicon-suspension-on-2-door-sport.40700/#post-919317
Stuckinthesand
CJ
NJ
2019 Wrangler Sport S
I run the same kit with 17x9.5 -18 offset. I put the spacers on and didn’t change anything else. No issues with tracking at all. I run 17 miles highway to work everyday. Not saying blnewt is wrong just my experience. If you go -12 you’ll poke 1/4 less and the -6 will be about 1/2 less.
Jeep Wrangler JL Help with wheel selection CE43D3E6-2500-4B92-9314-4ABD55E52A64
Jeep Wrangler JL Help with wheel selection 276BF410-BB2C-46FF-8302-9D61818E15AF
Jeep Wrangler JL Help with wheel selection FE2AE6C7-D115-48C1-8590-936D75A36969
Jeep Wrangler JL Help with wheel selection 940FEC72-2785-434B-B98A-D1DA63F78223
Jeep Wrangler JL Help with wheel selection A2DAFF21-EB28-40F8-9C67-8178467FDAF2
Maverrck
George
Rochester
Wrangler JL
Thank you to both of you for the insights !! That’s exactly what I was needing. Some legit advice from people who have done it.
