Help with wheel offset
Bruiser
Pat
Kansas
2024 Bronco Raptor, 2024 F350
I about to pull the trigger on a JLU and I will be installing the TeraFlex RT3 3.5" short arm lift. I want to run 38x13.50R 17 tires on beadlocks and I'm torn on which offset I should go with to have no or very minimal rubbing at full articulation and full lock with the steering. I want to keep my overall width as tight as possible just for narrower shelf roads/trails. I'm seeing some 0mm but I just don't think that is going to poke enough for clearance but I don''t know that either which is why I ask...
any help would be appreciated
thanks
Pat
lashlee
Knoxville, TN
'18 JLUR 2.0 Turbo 4 (Sold), Tesla M3P
My wife's JLUR has a MC GC 3.5" lift with Raceline wheels that are a -12 offset with a 40x13.50 MT Baja Boss that rub on the lower links at full lock but I'm fine with that since I wanted to keep the tires in close for the same reason.
Bruiser
Bruiser
Pat
Kansas
Perfect!!! That is what I needed to know. -12's is what they will be. Thank you Sir!!!!
Bruiser
Bruiser
Pat
Kansas
Not answering you question, but are you damn sure you need beadlocks? You're positive you'll be doing extreme enough stuff to require single digit PSIs?
Well, I understand where you're coming from and honestly I do agree with you BUT I am the type that would assume to have it and not need it instead of need it and not have it. I've thought about the Method Bead Grip wheels too. I dunno
The Last Cowboy
San Antonio, TX
2020 JL Willys 2 door
You don’t need bead grips unless you are crawling boulders at 5 PSI. If you want to keep your track width down, consider 12.50 width tires. If you want to keep your factory fenders and don’t want rubbing when you articulate, consider 37s. -12 offset with no more than a 9” wide wheel is good with 37s to strike a balance between rubbing and width. I’m going to guess that you already have factory 4.56 or 4.88 gears since you are even considering 38s.
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
Are there specific trails you're wanting to do that would need beadlocks? I've done things like the Rubicon and lots of Moab w/o them with no issues at all.
Hopefully you'll research what all is involved before buying a set. And yes, Brad Grips look extremely compelling.
fastguy
CO
2021 JLURD
Lots of gatekeepers around here. Enjoy your new wheel and tire combo. Post pics. :rock:
The Last Cowboy
San Antonio, TX
He asked for opinions and got them. That's not gatekeeping.
Jamrock
Jamaica
Suzuki
How many times have people jumped in and spent tons of money without understanding what they are doing?
Has he done the necessary prep work to prepare his Jeep for those heavy tires? What about the re-enforcement of the tailgate?
There is a lot more to 38 tires than offset. It is wise to listen to experienced people and learn from them.
