HELP!! What is this???
FLjeeper
Jason
Melbourne, Florida
2021 Jeep Rubicon JLU
I have a 2021 JLUR stock suspension with 2900 miles on it. It has been in 4H a dozen times or so pulling my boat out of a slippery ramp, and nothing crazy off-road yet. The sound bite is in first gear, rolling slowly and steering back and forth. Thanks for any help!
WranglerMan
Will
Greenfield Indiana
2018 Wrangler JLU Sahara
Early on there was an issue with clicking as you were turning the wheel and it was due to the ball joints not being torqued correctly, I have a 2018 and it was addressed by the dealer shortly after I got it, that may be your issue.
I would surely hope they are not still having this issue 3 years later, see this thread https://www.jlwranglerforums.com/forum/threads/clicking-noise-when-turning.9713/
FLjeeper
FLjeeper
Jason
Melbourne, Florida
I listened to some of the sound bites from that thread. Sounds like the same issue. Any clue what the torque specs are for the ball joints?
YippieKiYayMrFalcon
Rob
Atlanta
2021 JLU 80th Anniversary
I have a 2021, the issue still exits. I heard the clicking, went under there and torqued the lower ball joints and all is good now.
jessedacri
Jesse
Lake Arrowhead, CA
2019 Bright White 2dr JL Rubicon 3.6
You typically just want to advance the castle nut to the next hole and then reinsert the cotter pin. As the ball joint wears normally you'll start to hear it again later on, this is normal behavior for the most part though - once your ball joints are worn and ultimately need replacing I would go with an upgraded set. The stock ones have plastic internals.
zrickety
Technician
Second number is Ft Lbs
Jeep Wrangler JL HELP!! What is this??? 1624125153766
FLjeeper
FLjeeper
Jason
Melbourne, Florida
That's exactly what it was. I advanced the castellated nut two holes and reinstalled the cotter pin. It is an issue no more! Thanks all for the help!
