Help in identifying diff/axle
Terrymo
Terry
2023 JLURXR 3.6 ET
When they won’t even use a D-50 here even with the *V8 when Bronco uses a D-50, it certainly isn’t a 3/4 ton PU D-70. The size difference should be an easy eyeball, my PU has an 80 so no 70 pic but the damn thing is Huge. The ground clearance between it and my Jeep is substantial and the PU has true 35’s, not 33.8” C’s mounted with weight squat.
* possibly avoiding the weak point 4-auto TC
Standard Dana 50/60/70 is not even close to the M220 in size or bolt layout.
Jeep Wrangler JL Help in identifying diff/axle IMG_0061
LazyJL
Larry
2020 Rubicon, 2001 built XJ
Retired fabricator and mechanic
My motorhome has a Dana 70-HD, it's a beast with a 10-1/2" ring gear.
Jeep Wrangler JL Help in identifying diff/axle 35208907062_27fca5c004_4k
virkdoc
virkdoc
Ramandeep
Chandigarh, India
Cayenne V8, BMW 330i, BMW R1200GSA, Jeep Rubicon 2022
Will update in maybe 2 weeks.....Have ordered a diff cover for a Dana 44 and my friend will be opening it. Will post back
virkdoc
virkdoc
Ramandeep
Chandigarh, India
My buddy finally did the rear diff and sensor. The OEM sensor did not have oil in it but some metal shavings near the magnet.
The Nitro diff cover fit well. Posting a pic of what the diff looks like on the inside.
Also he said that it does have a drain hole which I had read the newer Jeeps did not have???
The front he said does not have the drain hole.
@Terrymo
Any conclusions on this…just curious
Jeep Wrangler JL Help in identifying diff/axle 613eed40-c1e0-43a5-a017-49f36eb4b53
Jeep Wrangler JL Help in identifying diff/axle 1a63d613-60bf-41f0-8228-7fd28f3eb3f9
Terrymo
Terry
2023 JLURXR 3.6 ET
@Terrymo
Thanks for the follow up
