HELP electrical circuit issues
Outback18
Aidan
NJ
2005 Jeep Wrangler
My dash and gear lights went out then my tail and now my low beams do not work. Any ideas on what it could be or how I could fix it? thank you
Outback18
Outback18
Aidan
NJ
2005 Jeep Wrangler
Yep they are all good
aldo98229
Aldo
Bellingham, WA
Market Research
Auxiliary battery...?
Wait, do you own a JL or a 2005 TJ...?
Outback18
Outback18
Aidan
NJ
2005 Jeep Wrangler
I will take a look thank you
dcmdon
Boston and Northern NH
2022 Gladiator Mojave
Its funny. I was thinking about having the OP start by testing for power at the switches and working down to the lights.
But then I realized that this skill is now useless with vehicles where everything is controlled by the CAN Bus. Ha.
SH556JL
Steven
Florida/Georgia
21 JLR M6 RIP, 23 JLR M6
Stuff like this worries me about modern cars… What’s the modern version of pulling the 8 track and pushing it off the cliff saying?
redracer
Robert
Manteca, CA
2023 4xe Rubicon
Utility I.T. Operations Technician
the only thing that those things have in common, to my knowledge, is they are all driven by the body control module (BCM). It could be a low voltage issue, but usually that will cause the canbus to go haywire and all sorts of things go weird at the same time.
Just the lights failing, to me, could only be the BCM failing... or possibly a bad ground.
Also, what does your dash say? When a light goes out, the BCM will notice that the circuit current draw will be not right and will flash a message on the dash. Another thought, if you have a Bluetooth OBDII adapter and JSCAN on your phone, you can scan for codes or even go into the BCM and command different things to turn on for testing.
Dyolfknip74
Ottawa, Ontario, Canada
2021 JLU Rubicon
I ran into some circuitry hell when I had a short to ground on a tag light I had tapped off of the passenger side tail. Park lights on pass side went out. Wouldn't come back. Fuses were good.
Just happened to catch on a wiring diagram that there is a seperate "fault wire". Removed the faulty light that was shorting and restarted Jeep. Good to go. The BCM does some weird shit. Lol.
mwilk012
Oklahoma
2018 Ocean Blue JLU Rubicon
Service
What kind of lights are you using here? Stock halogen, LED, or aftermarket?
Outback18
Outback18
Aidan
NJ
2005 Jeep Wrangler
My headlights and taillights are LED The rest that has gone out is stock. It’s so strange my high beams still work
mwilk012
Oklahoma
Service
Yes I have a TJ
Oh, you are in the wrong forum. This is the 2018+ JL forum, where problems like these are wayyyy different.
check your TJ for a bad ground orblown fuse. If neither of those, replace the light. Very basic electrical T/S.
Outback18
Outback18
Aidan
NJ
2005 Jeep Wrangler
Got it
