Electrical Issues
Netters2006
Annette
Missouri
2020 Jeep Wrangler Sahara
First time post
Dealing with electrical issues for over a month now and have been to two different dealerships.
Started with service engine light. Now a complete glitch of all lights (service stability, shifter, abs, 4wd) and red brake light is on. When this glitch occurs, I lose power steering and if I park and turn engine off, upon restarting cannot get vehicle out of park. Today I sat on the side of the road for almost an hour and was finally able to get it into drive to get it home.
gsbrockman
Greg
Sand Gap, KY
2023 Dodge Challenger Scat Pack Plus A8 & F8 Green
Owner / Operator Brockman Hauling, LLC
Have your battery(ies) properly load tested.
58Willys
Geoff
Western Washington
2018 JL Sport
Make sure all fuses are properly seated. Check battery grounds. Load test your batteries, replace both if even one is bad. If that doesn’t work, maybe a canbus connection issue.
m3reno
Sal
caldwell
2022 Jeep Wrangler JLU
What he said ^ It's a simple fix
Jtcal78
Josh
Oregon
2020 Jeep wrangler unlimited Willys
Read the threads I and many others have had. I replaced the Batteries. Did not help. Can Buss blocks behind the glove box. 2 of them. Easy fix. 7mm socket and 20min of your time. It led to me finding the real culprit, power steering pump was bad. And fried the Can Buss.
