Heated Rear Seats
tatarin
Russ
Bloomingdale, IL
2019 MOAB Mojito Sky One-Touch, 2015 Lexus RX350F-sport, 2005 Camry SE
Hey guys I’m currently working on installing heater pads in my rear seats. We’ll I’m just running the wiring and than take my seats to an upholstery shop whole will actually install the heaters under the leather!
Wiring is not my forte so my question is can I tap in to the wiring of the center console power outlet or should I choose something different? If power outlet which wires do I go for? I need Power, Ground and Accessory
Can anyone shed some wiring light on me?
pictures will follow
tatarin
tatarin
Russ
Bloomingdale, IL
Here is how I mounted the switches
and the wire I think I’m gonna tap in to
Jeep Wrangler JL Heated Rear Seats 27DCD0A5-10C7-42C0-B6FC-D446EE29BF0E
Jeep Wrangler JL Heated Rear Seats imag
Jabarsetti
Norman, Okahoma
2020 JLUR
Ret. USAF
That's super clean, what brand, is it a novice project, I read that your taking it to an upholstery shop. But, is it something that could be easier on cloth seats? Also, how much did they cost if you don't mind me asking.
tatarin
tatarin
Russ
Bloomingdale, IL
I would say anyone who can turn a wrench can do this. I just need to figure out which wire to tap into.
Amazon purchase and $200 for install of the heaters once I take the seats to the shop.
Jeep Wrangler JL Heated Rear Seats E5C0E073-1251-40DF-9227-9E08C35C98A3
Ormond Beach, Florida
Retired at 55 ..
@tatarin
I'm gathering that you have heated front seats from the factory right?
And, you do not have the Aux switches?
I probably would not power heated R seats from the 12v center console.. Personal preference and no more..
What is amp draw of your R heaters?
One way, of a few ways...
For 12v power, I'd probably fuse tap either F57 Frt Drvr Htd Seat 20 Amp Yellow Micro or F58 Frt Pass Htd Seat 20 Amp Yellow Micro . Will be quite easy to get the power wire from the rear seat area up to the driver's side where you will easily pass the wire through the grommet that covers the hole where your clutch would go through if you had a manual shift JL. Once through the firewall, the Main battery is say 3'+ away.
Another way:
Depending on whether you want on with ignition or always on , you can get the appropriate harness (depends on which you want to do) and use that harness in conjunction with the 12v cigarette lighter outlet. Easy access and no having to fuse tap, go through firewall, etc..
Harness(s) I mentioned can run $30+-.
And another way ... 12v receptable in the cargo area. That can be ignition switched or always on with the simple move of a fuse in the PDC.
For your reference:
F01 Spare
F02 Starter 40 Amp Green Cartridge
F03 IBS 5 Amp Tan Micro
F04 Fuel Pump MTR/FPCM 20 Amp Yellow Micro
F05 Security Gateway 5 Amp Tan Micro
F06 Spare
F07 LTR Cool Pump — If Equipped 15 Amp Blue Micro
F08 TCM-8HP CYGNUS 15 Amp Blue Micro
F09 Spare
F10 KIN/RF HUB/ESCL 15 Amp Blue Micro
F11 UCI Port (USB & AUX) 10 Amp Red Micro
F12 HIFI Ampliftier 25 Amp Clear Micro
F13 Spare
F14 Spare
F15 IPC/SWITCH BANK-HD ELEC 15 Amp Blue Micro
F16 Spare
F17 Spare
F18 AC CLUTCH 10 Amp Red Micro
F19 Spare
F20 CBC 1-INTERIOR LIGHTS 30 Amp Pink Cartridge
F21 REAR WIPER 20 Amp Yellow Micro
F22 ECM/PCM/MGU WAKE UP/PPU WAKE UP 10 Amp Red Micro
F23 PCM/ECM 10 Amp Red Micro
F24 Spare
F25 MOD_SBW 10 Amp Red Micro
F26 CBC 2-EXTERIOR LIGHTS #1 40 Amp Green Cartridge
F27 Front Wipers 30 Amp Pink Cartridge
F28 CBC 3-POWER LOCKS 40 Amp Green Cartridge
F29 CBC 4-EXTERIOR LIGHTS #2 40 Amp Green Cartridge
F30 Spare
F31 DIAGNOSTIC PORT 10 Amp Red Micro
F32 HVAC CTRL MOD/SCL/OCM/DPDM 10 Amp Red Micro
F33 PTS/IRCM/AIRBAG DISABLE LMPS 10 Amp Red Micro
F34 ESC/EHPS/SBCM WAKE UP 10 Amp Red Micro
F35 BRAKE VAC PMP — If Equipped 30 Amp Pink Cartridge
F36 TRLR TOW MOD — If Equipped 30 Amp Pink Cartridge
F37 TRLR TOW CONN 7W — If Equipped 30 Amp Pink Cartridge
F38 ECM 20 Amp Blue Cartridge
F39 Spare
F40 DTCM/AXLE LOCK FT_RR 15 Amp Blue Micro
F41 IC/SGW WAKE UP 15 Amp Blue Micro
F42 PCR CTRL FEED (ESS)/SPARE (BSG) — If Equipped 10 Amp Red Micro
F43 PWR OUTLET (CARGO) BATT 20 Amp Yellow Micro
F44 IRCAM HEATERS 10 Amp Red Micro
F45 PWR OUTLET (CARGO) IGN* 20 Amp Yellow Micro
F46 AUTO HDLP LVL MOD/LVL MTR/HDLP SW 10 Amp Red Micro
F47 Spare
F48 Spare
F49 ORC 10 Amp Red Micro
F50 HD ACC — If Equipped 10 Amp Red Micro
F51 DSRC/USB/ISRVM/CSGM 10 Amp Red Micro
F52 CIGAR LTR 20 Amp Yellow Micro
F53 Spare
F54 Spare
F55 Spare
F56 IN-CAR TEMP SENSOR 10 Amp Red Micro
F59 Spare
F60 CSWM (HTD STR WHEEL) 15 Amp Blue Micro
F61 LBSS/RBSS 10 Amp Red Micro
F62 Spare
F63 ORC 10 Amp Red Micro
F64 Spare
F65 Spare
F66 HVAC BLOWER MTR FRT 40 Amp Green Cartridge
F67 Spare
F68 Spare
F69 MGU (BSG) — If Equipped 5 Amp Tan Micro
F70 INJ/IGN COIL (GAS)/GLO PLUG MOD (DSL) 25 Amp Clear Micro
F71 Spare
F72 HD ELEC ACC PKG — If Equipped 10 Amp Red Micro
F73 PWR TOP LT 20 Amp Blue Cartridge
F74 PWR TOP RT 20 Amp Blue Cartridge
F75 PPU-BPCM & APM (BSG) — If Equipped 10 Amp Red Micro
F76 ECM (GAS)/PCM (DSL) 20 Amp Yellow Micro
F77 HTD MIRRORS 10 Amp Red Micro
F78 COMP/INTRUSION/SIREN/INTRUSION SNSRS 10 Amp Red Micro
F79 SMART BAR CTRL MOD 20 Amp Yellow Micro
F80 PCM 15 Amp Blue Micro
F81 REAR DEFROSTER (EBL) 30 Amp Pink Cartridge
F82 FUEL HTR — If Equipped 30 Amp Pink Cartridge
F83 GLOW PLUG — If Equipped 60 Amp Yellow Cartridge
F84 UREA HTR CTRL UNIT — If Equipped 30 Amp Pink Cartridge
F85 PM SENSOR — If Equipped 10 Amp Red Micro
F86 BRAKE VAC PMP 2 — If Equipped 30 Amp Pink Cartridge
F87 SUPPLY/PURGING PMP — If Equipped 10 Amp Red Micro
F88 NOx SENSOR #1/ #2 — IF Equipped 20 Amp Blue Cartridge
F89 SCCM/CRUISE CTL/DTV 10 Amp Red Micro
F90 TRLR TOW PARK LMP — If Equipped 20 Amp Blue Cartridge
F91 HORN 20 Amp Yellow Micro
F92 HD ACCY #2 — If Equipped 40 Amp Green Cartridge
F93 HD ACCY #1 — If Equipped 40 Amp Green Cartridge
F94 TPM/CORAX 10 Amp Red Micro
F95 Spare
F96 PWR MIRROR SW 10 Amp Red Micro
F97 RADIO/TBM 20 Amp Yellow Micro
F98 SW BANK-HD ELEC/OFF ROAD 10 Amp Red Micro
F99 Spare
F100 ESC-ECU & VALVES 30 Amp Pink Cartridge
F101 DTCM 30 Amp Pink Cartridge
F102 DUAL USB PORT 15 Amp Blue Micro
F103 HD ACCY #3 — If Equipped 15 Amp Blue Micro
F104 PPU COOL PUMP — If Equipped 15 Amp Blue Micro
F105 ICS/HVAC 10 Amp Red Micro
F106 ESC-PUMP MTR 40 Amp Green Cartridge
F107 TRLR TOW STOP/TURN LT — If Equipped 20 Amp Yellow Micro
F108 HD ACCY #4 — If Equipped 15 Amp Blue Micro
F109 TRLR TOW STOP/TURN RT — If Equipped 20 Amp Yellow Micro
F110 POWER INVERTER 30 Amp Pink Cartridge
F111 TRLR TOW BACKUP — If Equipped 20 Amp Blue Cartridge
tatarin
tatarin
Russ
Bloomingdale, IL
Awesome thanks so much.
tatarin
tatarin
Russ
Bloomingdale, IL
I did use the center console wiring. If I remember correctly I used the ground and power from the wiring harness of the ac power adapter that’s back there. Super easy to access all the wires and run them under the carpet.
Extremneon
Montgomery, Al
2021 Jeep Rubicon Unlimited
Thanks,
at the connector?
Jeep Wrangler JL Heated Rear Seats AB44D717-68B2-49A3-86E7-B25D88551291
tatarin
tatarin
Russ
Bloomingdale, IL
Pretty much, I used posi-tap to tap the wires
Mikehikespnw
Washington
2021 JL Sport S Unlimited
are you still happy with this kit? I like the buttons over the standard rockers that are sold with other seat heaters. Just an off brand so i worry about durability vs something like dorman
tatarin
tatarin
Russ
Bloomingdale, IL
I am, had it for 4 years now still works great
