Hard Top to Soft Top And Back
barrydd
Kentucky
2022 Jeep JLUR
How much trouble is it to switch back and forth between hard top and soft top?
Thanks...
Carnut12
Forsyth, GA
2019 Ram 1500 Limited, 2020 BMW M4
Complete PIA especially if you have any lift/tires that make it higher. Enough that the Skytop is the only Jeep I would buy.
Overkill
Paris, IL
Rubicon392.com
2024 392;2002 TJ Sport;2005 GMC 2500HD;1969 Camaro (x2);1974 Chevy Cheyenne K20
Information Technology
Thanks...
If you have a hardtop hoist, not that hard. I change mine out spring and fall. Do my TJ also. The hardtop is just 8 bolts (4-door, not not sure on 2-door) and the Freedom panels. The softtop has the door surrounds to install and a couple of brackets for the back window bar to snap in to. I leave the sportbar brackets for the softtop to mount to on all the time.
Would be a pain if you wanted to switch back and forth every other week, but a couple of times a year it isn't too bad.
lowmpg
Ryan
Kent Island, Maryland
2021 Rubicon, 2025 Ram Limited
It's simple, not sure what people complain about. I do it every season, soft top in the summer, hard top in the winter. I've used a Hoist-a-Cart (when alone), I've also used suction cups to pull the hard top (when I have one other person to help). Putting the soft top on takes less than 30 min. Again, not sure what the issue is here aside from having to store a hard top.
I have 37" tires and a 2.5" lift, and I do this in a standard home garage.
barrydd
barrydd
Kentucky
2022 Jeep JLUR
Its simple, not sure what people complain about. I do it every season, soft top in the summer, hard top in the winter. I've used a Hoist-a-Cart (when alone), I've also used suction cups to pull the hard top (when I have one other person to help). Putting the soft top on takes less than 30 min. Again, not sure what the issue is here aside from having to store a hard top.
Seasonal is what I was thinking.
Thanks all for the replies...
Rmartinson
Rory
Minnesota
2018 Jeep Wrangler JL
Yes I do mine in the fall and spring as well. I have a homemade hoist in the ceiling of my garage. Hard top hangs from it all summer. It makes it a 1 man job. Total time for the conversion is about 1 hr.
Industrialwrench
San Diego
08 SRT Challenger. 18 4Runner off-road premium.
Well for a 2 door It’s a very simple process to change the tops. I do it a couple times a year. Takes about 30 mins. I’ve got 3.5” lift and 37” tires. I do it all by myself. I use a little step ladder at the tail gate and I set them down on a few pre set carpentry horses. There’s a couple brackets for the soft top and I use a couple straps to keep the soft top bundled while I install and remove.
The Fixer
North Jersey
2018 Mojito! JLS, 2018 Firecracker JLUSS
Teacher
Seasonal is not bad at all. My son and I have been swapping the hardtop/soft top almost every spring and winter on my wife's JLU since 2018. We didn't do it last year because we have a car in the garage now where I used to put the hard top, but he stored the hard top for his JLUR at a buddy's storage unit.
Might look into one this season big enough to put the two tops in, or a small shed to build for the yard.
Murphydog
Seattle
2020 X3M, 2023 JLUR XR
I have a garage and manual hoist. Take about 30 -45 minutes. Placing the soft top into the mounting brackets was awkward the first time but I’ve got better with practice.
barrydd
barrydd
Kentucky
2022 Jeep JLUR
Thanks to all for the feedback.
