Hard shift into 4H
Jondrew
Bob
Central Fl
2018 Rubicon
How many times have you tried? First few times with mine were stiff. Now it’s loosened up and its no effort.
TimmH
Timm
2018 JL Wrangler Sahara 3.6 Auto
Mine was the same way. Almost seemed like it wouldn't shift at first, now after doing it several times, it shifts easily.
Jondrew
Bob
Central Fl
2018 Rubicon
Now if I can just get 4WD Low down so it doesnt sound like I’m going to grenate the transfer case
OldGuyNewJeep
Don
CT
frankmorris
Albuquerque
2019 JLU
I’ve shifted maybe 15 times in the last few days and it’s just as stuff. But, it sounds like it’s a normal experience. Hopefully it will subside over time.
Gadgetguru
Pennsylvania
2018 Jeep Wrangler JLU Sahara
So my wife said the same thing about shifting into 4H the first time and that it banged and popped back out. She had a difficult time getting it back into 4H. Since then she has been using it in the snow without issue to my knowledge.
However, last night I changed the oil and saw what looked like some kind of oil, yellow, slippery (maybe mixed with water) around the transfer case linkage. Looks like the driveshaft had spun and sprayed it.
Jeep Wrangler JL Hard shift into 4H IMG_20190204_184813
Jeep Wrangler JL Hard shift into 4H IMG_20190204_184803
Jeep Wrangler JL Hard shift into 4H IMG_20190204_184733
DavidArmen
Los Angeles, CA
2021 JLUR
Did you ever discover what this was?
libis22
Libin
Atlanta
Triumph Daytona 675R, Willys sport XR
Electronics engineer building software
I had same issue yesterday with 4H to 2H shifting on 100 mile ran Jeep.
Finally it shifted. I tried when the Jeep was cold. I will try again when properly warmed up and see if that helps.
UPDATE- Much better when the jeep is warmed up. First time I shifted it was 45F and vehicle was cold, second time, similar temp but tried after a 25 mins drive and shifted from 4H to 2H and back without any issues.
