Full time 4WD.
Wbino
NJ
So basically it's 2WD till it feels slipperage then gives power to the other axle?
Ed Pursell
-Ed-
Lehigh Valley Pa, Allentown
2021 JL Willys- 3.6 Pentastar,8 speed Auto, Selec-Trac transfer case
Supervisor- MRO Buyer Maintenance- Pet food Mfg.-Now Retired.
Yes, very nice option, wasn’t an option on my 2012, or my 2016 Willys, so when I ordered my 2021 Willys last Oct. , it was a no brainer. Works great for daily driving in my neck of the woods due to covered surfaces, next block blacktop, then again un-paved 6” plus snow covered roads.. When we get hammered with snow, it’s 4 h . To me, worth the $700.00 bucks.
Reinen
2021 Jeep Wrangler JL Rubicon
Yes, and I 2nd that on the seamless & imperceptible. It's ideal for intermittently snow covered roads.
wanderer
Ralph
Carlsbad CA
Engineering Geologist
So. Can you run it in 2 whl say like in so cal until you get somewhere like the mountains with rain snow etc. then put it in whl auto.
is that the same system the grand Cherokee trailhawk uses? If not what is the difference ?
aldo98229
Aldo
Bellingham, WA
Market Research
Yes.
No. Selec-Trac has not been offered on Grand Cherokee since 2004. Grand Cherokee comes with Quadra-Trac I, Quadra-Trac II and Quadra-Drive.
Grand Cherokee 4WD systems now rely heavily on electronics to prevent you from getting stuck; you can thank Daimler for that. Even the rear limited slip diff on Trailhawk is now electronic, whatever that means.
Quadra-Trac I is essentially AWD, and is only available on base models. Quadra-Trac II and Quadra-Drive, on the other hand, offer selectable part-time 4WD modes like a proper Jeep, with low range and neutral.
Thankfully, Wrangler’s Selec-Trac remains analog. The transfer case shifting has gone electronic, though...
Tyler-98-W68
Tyler
Canada
2021 Sahara 4xe, 2022 Rubicon 4xe
Yes.
Grand Cherokees 2011+ as long as they have Quadra Trac II have the same MP3022 Transfer Case used in the Wrangler JL. The difference in the Grand Cherokee is they don't have a selectable 2H mode.
This is how the system works in a JL
https://www.4xeforums.com/threads/m...n-and-monitoring-with-j-scan.2602/#post-31415
