Fridge / Slider options
Tx_Wrangler
Geoff
Central Texas
2024 Wrangler Rubicon
I have a Wrangler JLU with a Hooke Road cargo rack in the back.
I am look at installing a fridge slider but since the Iceco APL35 is a front opening I need to clear the cargo rack when fully extended. I have looked at Goose Gear floors and sliders, GG floor with Iceco slider, AAL floor, ect.
Having a hard time getting exact measurements before dropping some money on a system.
Anyone have a setup that works?
Thanks
Jeep Wrangler JL Fridge / Slider options IMG_0652
Nokones
Kenny
Sun City West, AZ
I am using a Dometic CFX345 in my 23 Wrangler Rubi 2 Dr. and I elected not to use a slide out tray Mount because it would have taken of valuable floor space for my Trail Recovery Gear that I take on all of my runs.
Jeep Wrangler JL Fridge / Slider options 20251028_143713
wwtucson
William
Thousand Oaks
2023 jeep wrangler Rubicon
Thanks
I installed the 50L ARB fridge/Freezer from the JK to my 2023 JL. I removed the original carpet/base. With the anchor bolts removed I used screws with points in the holes to transfer the locations onto the 3/4" plywood base. I placed the ARB tray on the plywood to locate the hatch opening cut. A 12 inch ribbon hinge worked perfect. Because 3/4" plywood is under sized I trimmed it with 3/4" aluminum. Indoor/outdoor carpet covered the plywood. I built a box to cover the tray when the fridge is removed. I also built a box around the fridge so camping items did not fall behind it when pulled out. Cutouts in the back of the box provided air space for the compressor. I installed an A/C power receptacle to power the fridge when power is available.
Jeep Wrangler JL Fridge / Slider options Fridge Tray Plywood Base Setu
Jeep Wrangler JL Fridge / Slider options Plywood Bas
Jeep Wrangler JL Fridge / Slider options Base Installed with Hatch
Jeep Wrangler JL Fridge / Slider options Tray Base With Hatch Open
Jeep Wrangler JL Fridge / Slider options Tray Extended
Jeep Wrangler JL Fridge / Slider options Base Tray Complet
Jeep Wrangler JL Fridge / Slider options Fridge Installed
Jeep Wrangler JL Fridge / Slider options Fridge With Cover-Box_1
LanceMagnum
New England
2020 JLUR
if you don't need a portable fridge a drawer fridge saves the weight of the slider and also uses the space a little more efficiently (as compared to a Goose Gear module) - this one is 65L in a DIY 80/20 'box' (that I later added a couple of storage drawers to)
Jeep Wrangler JL Fridge / Slider options 1761761432945-i6
