zouch
- Sep 17, 2020
- Berkeley, CA
- XJ, JLUWD
point is, the way the setup i described works, the Portable battery only draws off of the vehicle when the engine is running, so nothing draws down the Starting battery.
the fridge can run whenever it wants to as long as the Portable battery is charged, whether the engine is running or not.
in the ambient temps you're dealing with, you're probably going to have to use all the tricks, starting with making sure that the vents for the refrigerator are clear and unblocked to allow the proper exchange of heat from the fridge to the air in the vehicle. but it's going to be hard to get heat out of the box if it's trying to exchange it into air that's 136º.
none of this explains your original question of why your fridge is able to draw down your starting battery.
That is a great idea really ! And that is exactly what I need, to make the fridge run only while the engine is on
