Fox ATS
AC77
AC Abegian
Los Angeles
Autobody , singer-songwriter
Hello
does the new steering damper need to be installed first then an alignment ? Or vice Versa ?
Thanks
CarbonSteel
Steering damper first, but typically the only thing that needs to be corrected is the steering wheel position (which can be easily done with a small change on the draglink).
AC77
AC77
AC Abegian
Los Angeles
Thanks for the reply sir. And what is the change you’re referring to ?
Do tell
davewald
Bellingham, Washington
www.davewaldrop.com
2021 Wrangler Rubicon
Sort of, kinda retired....mostly
It really doesn't matter. Alignment mostly only deals with caster, which is set by the control arms, and steering wheel centering, which is easily set by the drag bar. I had mine aligned before I installed the Fox ATS Race stabilizer and it handles just fine after installation. You can adjust the steering wheel centering yourself, since it's just a matter of loosening or tightening the drag bar. I have adjustable lower control arms, so setting caster is fairly simple, too, though I take it to a local jeep guy with a machine to have it set instead of doing it myself with an angle finder.
Beachcomber72
2022 JLU High Tide
If you live anywhere close to a saltwater environment and or deal with lots of road salt I’d highly advise to stay far from the ATS, the pass through shaft pits and corrodes very fast. Hence destroyed shock seals.
zouch
Berkeley, CA
XJ, JLUWD
a proper alignment will include adjustment of Toe-In.
since many Steering Stabilizer upgrades move the SS up above the Tie Rod and clamp directly to the Tie Rod, you'd want to do your Alignment *before* you clamp your SS to the Tie Rod.
davewald
www.davewaldrop.com
He’s asking about the Fox ATS stabilizer. It bolts onto the factory mounts, and isn’t above the tie rod.
zouch
Berkeley, CA
XJ, JLUWD
i have a Fox ATS Stabilizer; it mounts above the Tie Rod with a clamp to the Tie Rod.
he wasn't specific about which configuration he was using; i didn't assume.
zouch
Berkeley, CA
XJ, JLUWD
i'd add that even if it's the JK version installed with the Above-the-Tie-Rod adapter kit (that is so popular to get the SS up to where it's no longer a rack magnet) it *shouldn't* need to be aligned.
i personally wouldn't bother putting an upgraded SS on down where it's the first thing that's going to get munched on a trail ride, and would do the relocation conversion at the same time.
but the way these J**ps are delivered, it's hard to know how far off your alignment is unless you check, and you're going to want to do that before you clamp anything onto the Tie Rod.
If it is the JL version, installed as intended, no alignment is needed.
