Flat Tow Mode?
Flyn G
Lance
Conway, AR
2021 Wrangler Rubicon
Pilot
I don’t get the Owners Manual procedure. It’s easy enough, just don’t understand why the engine shutdown, neutral transfer case, then restart. Is there something on the automatics? My manual JLR seems to pop in and out of neutral transfer case easily either way. Doing the reverse/forward test to confirm seems prudent. I am curious if there is an actual tow mode that we are setting the computers to prior to towing it with the start sequence. Anyone know?
JRINGO77
Houston TX
2021 JLUR
I think the restart is just to confirm t case is actually in N. Same sequence for flat tow since I can remember.
jludave
The Isle of Long
IT Manager
Anyone know?
As mentioned above, it confirms the vehicle transfer case is actually in neutral. If you restart the vehicle and it moves in forward or reverse, it's likely because the t-case is not in neutral. It's a safety check.
Jim_n_Tx
Jim
Texas Gulf Coast
TJ, Commando, JT , JL, M422
My two-door automatic has a a dash light that reads "Neutral" when the transfer case is indeed in neutral. It helps with the vague feel of the t-case lever.
Flyn G
Flyn G
Lance
Conway, AR
Pilot
Yup, but the Jeep procedure is engine off, neutral, engine on, and test. If there isn’t a reason for it, it makes no sense.
Jim_n_Tx
Jim
Texas Gulf Coast
Things that make no sense haven't stopped Jeep before.
