First Mod - MORE Dead Pedal
Cthehentz
Kev
Vegas
Jeep JLU
This is a must upgrade, I am going nuts like where the hell do I put my foot (3,2,1) big dead uncomfortable space.
RichD
Rich
Boston
2018 Sport S
I finally got around to installing the pedal yesterday. Not sure of the brand, it was a gift. Yup, a pain to install. My body doesn't contort like it used to! I had to mount the pedal section all the way back because of the position of the bracket holes. A very poor design. I'd rather have the pedal height much closer. I may remove, rebuild and reinstall it after my back recovers.
Jeep Wrangler JL First Mod - MORE Dead Pedal 20200327_111051_resized
Will_Jeep
Will
Atlanta
Black 2108 JKU Sahara, Black 2016 Mercedes CLS400
When I installed mine, first time I put it on the furthest setting, and it took a few minutes, but I decided that I wanted it closer :facepalm:
Twenty minutes later, and lots of twisting and squirming I had the middle setting done.
What I figured out is that an offcut of 2"x1" drops down behind the thing inside the frame and holds it in place while you bolt everything together!
Focker
Sacramento, CA
www.ducati.ms
2020 Jeep Rubicon
General Manager
What I figured out is that an offset os 2"x1" drops down behind the thing inside the frame and holds it in place while you bolt everything together!
That is a good idea I hadn't thought of. I installed mine yesterday and first tied some thread around it in case I dropped it initially and then put a zip tie around it to hold it in place while I got the bolts on. I also stuffed a rag in front of the bracket just in case I dropped a washer or nut. Took about 10 minutes to do the entire process using the closest setting of the 3 options.
Jeep Wrangler JL First Mod - MORE Dead Pedal P1002225-XL
Will_Jeep
Will
Atlanta
@RichD Auto correct, should have been offcut!
Adamoni
2020 Rubicon Recon (2.0T w/ eTorque)
The MORE pedal looks ver very similar to the one RichD installed minus the propaganda sticker. @RichD can you find out what brand your gifted dead pedal is?
mgroeger
Southern UT
2021 JLUR 2.0T
Hopefully this helps. It’s placement is similar to a clutch. Also. I have it set to the nearest setting. I tried it alway the back and I could barely reach it. I’m 5’11” for reference.
Hmmm... I don't much care for your socks.
RichD
Rich
Boston
2018 Sport S
No documentation in the box. Sticker on the box front says "Cartaoo". I've seen similar ones on Amazon.
Will_Jeep
Will
Atlanta
@Adamoni we can see your list, and others!
It looks like Monica needs new shoes.....
Jeep Wrangler JL First Mod - MORE Dead Pedal Screen Shot 2020-04-02 at 8.08.01 AM
Adamoni
LOL thanks for the heads up especially before SHE saw ;)
I set public lists to private so hopefully only the ones I shared now is visible. Can you check that and also, when you are inside the list, can you see my notes? (Should be a price and PFR (Prime Free Return).
Will_Jeep
Will
Atlanta
Adamoni
@Adamoni this is what I see now :)
Awesome. I try to keep track of lowest prices in the notes.
by the way @everyone I have no affiliation with any product here and don't get anything if you use my list to find your dead pedal; just sharing the love!
