Finally overheated
RicRecon
Ric
NorCal
2021 JLUR 3.0, 2021 JT Overland 3.0
You guys keep ringing the bell
jav_eee
2021 JTR
I sure hope he has a good explanation that defies physics. That’s how it’s worked in every other car made prior to the JL.
it kinda makes sense. You can see temps climb while driving. Until the fan kicks on.
ALeeL
Anthony
2021 JLURD
You have a 3.0L diesel with a bunch of restrictive exhaust parts pumping out 260 hp (87hp per liter) in a heavy vehicle that is as aerodynamic as a brick, which causes more load the faster you go, and asking it to tow even more weight causing even greater lead. What would one expect to happen?
For reference, my 6.7L Cummins truck was at 375 hp(56hp per liter) new, is in a more aerodynamic vehicle, and has not one, but two massive radiators. Power equals heat and creating more power in a smaller package will create a lot of heat, especially if you block off the exhaust with a huge filter.
Another issue is that since the US has so many restrictions on diesels versus gas engines, the engine may also be cutting power reduce your emissions. NOx is only created under high heat situations. Hence the reason why lightning strikes and forest fires create a ton of NOx — one lightning strike will create more NOx than thousands of deleted diesels.
Under high sustained load, your diesel will create a lot of NOx and the engine may be programed to defuel if the system cannot keep the NOx under a certain amount.
Willys41
Larry
Pleasanton Ca.
2020 Jeep Willys
After 6 months tiring different thing to keep the jeep running cooler this is what I found out.
1. I tried the grill inserts. NO difference.
2. removed winch for better air flow. NO difference.
3. Installed the 940 watt fan motor. NO difference.
4. Installed high volume high pressure pusher fan on the A/C condenser.
With the pusher fan what was happening is the air would go through the condenser hit the radiator and bleed out all the opening between the condenser and radiator. Almost NO air would pass though the radiator.
5. Replace the radiator with a Mishimoto radiator hopping it would allow more air to pass though.
Still with the Mishimoto almost no air would pass though the radiator.
6. Closed all the gaps between the condenser and the radiator. STILL VERY LITTLE AIR WOULD PASS THROUGH THE RADIATOR WITH THE PUSHER FAN.
Conclusion. Today's radiators air build with tight fins and do not pass free flowing air like the older radiator. If you think driving your jeep down the road at 60mph you getting massive amounts of air flowing through your radiator YOU ARE NOT.
The jeep radiator will only work with air being sucked through it with a fan and it works well put the fan comes on to little to late.
7. Installed a RPM Extreme JL fan controller. Problem solved. NO more 235+ coolant temps or high oil temps. I have reduced the oil and coolant temps by 25+degrees.
THE END.
As far as physics.
Air will always find the path of least resistance. And its not through the JL radiator.
zouch
Berkeley, CA
XJ, JLUWD
remind us; is yours an EcoDiesel?
i’m looking for anyone who has gotten the Fan Controller to work on an EcoDiesel like the OP has.
THE END.
As far as physics.
Willys41
Larry
Pleasanton Ca.
2020 Jeep Willys
3.6
Jon at RPM extreme one day may have one for the EcoDiesel.
I think that someone brought there 2.0 and was able to make one.
I think what he needs is to have an EcoDiesel for testing.
Wrangler man
Howard
Palm Springs
2020 JLUAD
From my research and searching the aftermarket engineers have not had the opportunity to have a EcoDiesel platform in their possession to do the necessary testing. Therefore it is not available on the EcoDiesel at this time. I was told if they have the ability to have the EcoDiesel Wrangler in their shop for the necessary tests then and only then would they know if it's going to be doable so it could be made available. Currently only the 3.6 and the 2.0 I think they've started some research on the 392. They followed up saying if someone dropped off an Eco diesel they would definitely give it a try
zouch
Berkeley, CA
XJ, JLUWD
yeah, that jives with what i keep hearing as well.
so, still not an option for the OP.
3.6
CorvZ061
Travis
Amarillo, TX
'24 JLUR 6MT
THE END.
As far as physics.
Air takes the path of least resistance. And if you sealed the area off between the condenser and radiator then where it the air going? Not back forward.
DarthAWM
Mick
Odessa, TX
2021 JT Rubicon
Oilfield Dispatcher/Semi-Professional Adult Film Star
ALeeL
Anthony
2021 JLURD
After 6 months tiring different thing to keep the jeep running cooler this is what I found out.....
Seems like you tried a lot of different things. Have you done anything in regards to creating a lower pressure in your engine bay to suck out all the hot air under your hood? I was thinking about doing this just to see if it would work. I already have a long thin strip of 2.5" plastic that I saved from another project that I can mount to bottom of the front bumper skid plate. Something I can take off when I go off road. I am curious to see if it would work, but never got around to it.
Willys41
Larry
Pleasanton Ca.
2020 Jeep Willys
I could not close all the gaps and yes it would find any place to escape and would not go though the radiator core.
I tried several different fans motors and fan combination and was pushing air at over 120mph and still could not get enough air going though the radiator that I could even measurer.
Willys41
Larry
Pleasanton Ca.
2020 Jeep Willys
I drove around with my head lights removed, hood not latched. No difference.
You hove the hole underside of the motor letting out air.
You could remove the hood and it not going to increase the air going though the rad. core.
mgroeger
Southern UT
2021 JLUR 2.0T
Any details on the fan? I want to do what I can to keep mine cool as I plan to tow my camper.
Grab yourself grill inserts from a JT or newer JL, they are significantly larger and allow more air flow. Cut your hood vents open to be real hood vents. Yes, I know air does not really get pushed out of them it simply helps a little while driving but a lot when sitting still. It keeps the engine from heat soaking. Get rid of that stupid engine cover, it's useless and only keeps more heat trapped in there. If you have the turbo and after market inner fender liners pop the driver's side fender liner out and it helps a lot. My wife was pulling a long uphill grade on I-15 in 100 degree temps with A/C on and these mods helped a lot. These are super cheap simple mods that can help the engine from getting so hot.
Jeep Wrangler JL Finally overheated PXL_20241231_195252266
