Filler cap issue - anyone else?
shufly09
Alex
Newport Beach, CA
2020 Ecodiesel JL Rubicon
Something weird happened to me earlier today when I tried filling up my jeep. When I put the diesel nozzle in, it wouldn't enter. The metal flap, for whatever reason, seemed to be stuck closed. I felt around and tried pushing on it, and it still didn't open. Planning to swing by the dealer tomorrow so they can check it out, but has this happened to anyone else?
WagzDad
Carroll
South Louisiana
Any chance the guns were switched on the pump? Was it a tax free Or kerosene pump ?
rob58
Rob
Steinhatchee, Florida
2020 JLUR
Retired Chemical Engineer
It happened to me a couple of months ago. 1000 miles from home! Decided to push it hard until it gave way. It worked and hasn't happened again. Just push it on in!!!
EcoDRubi1
Greg
Bowling Green Ky
2020 jl eco diesel. 2020 gladiator
There is a nozzle for oversized diesel fillers under the compartment in back of jeep. I had same issue. Some fit some dont
Compression-Ignition
Roy
Montana
'22 JLUR 3.0 Diesel, '20 6.7L F350, '94 12 valve
If it fits in far enough to touch the metal flap but will not push the flap open, try to pull/push down on the handle. That will release the spring loaded mechanism and allow the nozzle in.
If it's too big then use the adapter.
RubiBlueJLU
Missouri
2021 JLUR Diesel
Structural Technician
I ran into the "same" issue before. My issue was that the diesel "gun" was the same size as the unleaded, so it was too small to release the flap. Used the adapter to fill it up,
Another time, the diesel "gun" had an added ring on the end, so it would not fit, either. I had to hold it against the adapter to fill up. Slow and long fill.
