Expeditious advice needed for bump stop installation
Drakon21
Grant
Elk Grove
None Yet
Hi smarter people than me.
I am currently in the middle of doing a solo spring swap/Bump Stop addition. I currently have the springs out, and have the shocks in, trying to measure how much bump stop I need. I currently have 2 inch bump stops on the front, but have ran out of wood blocks and jack right as the bump stop is contacting the jounce. It appears I have about hair more than 2 inches of shock travel left, and a hair less than 2 inches of Jounce before the hard metal. I was wondering if I could get your fine opinions on if I need to add more or less bump stop? The faster the better please I’ve got the jeep in the air and everything lol.
Jeep Wrangler JL Expeditious advice needed for bump stop installation IMG_4641
Jeep Wrangler JL Expeditious advice needed for bump stop installation IMG_4642
Jeep Wrangler JL Expeditious advice needed for bump stop installation IMG_4643
Roky
Roky
Just going by the pics, looks like you’ll have close to 1/2 , maybe 3/8” to the good…. Should be good..
LazyJL
Larry
2020 Rubicon, 2001 built XJ
Retired fabricator and mechanic
The Factory bump stops can compress to the metal holders.
I suggest adding another 1/2" of spacers so the shock never bottoms out. I like to have a minimum of 1/2" of unused shock travel to protect the shocks from exceptionally hard hits. Metal flexes under heavy loading.
To check the travel once assembled, I place a small zip-tie on the shock's shaft to determine the actual travel and how close the shock comes to bottoming out.
Roky
Roky
If you decide you want another 1/2” and don’t have something already, I bought some hockey pucks off the amazon and made my own….you can get just one for 5.00. I ran mine through the table saw and drilled a hole in it, works great……
Jeep Wrangler JL Expeditious advice needed for bump stop installation IMG_8945
Jeep Wrangler JL Expeditious advice needed for bump stop installation IMG_8951
Jeep Wrangler JL Expeditious advice needed for bump stop installation IMG_8957
Jeep Wrangler JL Expeditious advice needed for bump stop installation IMG_8952
Drakon21
Drakon21
Grant
Elk Grove
None Yet
Thanks everyone.
I added an extra half inch just to be safe.
failsafe306
Tulsa
2022 JLUR 2.0
That’s a cleaner solution than what I did when I needed another 1/2” of bump up front. I just grabbed a black poly cutting board out of the cabinet and drilled out a 3.5” hole with a hole saw 😆
Camaroboi13
Justin
San Bernardino, CA
2022 JTOD, 2024 JLU W
LEO... life in Chino
I’d leave it alone. The bump stops will compress. Mine are pushed so far in there’s only half inch of bump stop sticking out 😂
Roky
Roky
🤣…….. well that’s better than what I had on there before……. It was a 3/4” nut, which, surprisingly, is right at a 1/2” thick…. 😂….
Jeep Wrangler JL Expeditious advice needed for bump stop installation IMG_6916
