Excessive weights? Tire balance
lowmpg
Ryan
Kent Island, Maryland
2021 Rubicon, 2025 Ram Limited
gsbrockman
Greg
Sand Gap, KY
2023 Dodge Challenger Scat Pack Plus A8 & F8 Green
Owner / Operator Brockman Hauling, LLC
Just had my tires replaced on my 2019 JKRU, stock tires, KO2s.
Discount Tires
Counting 21 each 1/4 weights, plus 3 on the inside on the rim edge (on one wheel, others similar)
does this seem excessive?
Question......are the stick on weights around or near 180° out or away from the clip on weights?
Looks like a major phoccccckkkkkkkk up to me....
Some Random Guy
Washington
Comptroller
Yeah, my beadlocks have fewer weights. A good shop can probably redo that for $10.
Doubleaaron
New Mexico
2019 Rubicon JLU
Do​
Goodyear should of had the dots indicating highest point (red)
Lightest point (yellow)
Maybe have discount mark the tire centered on the weights and move that point inline with the valve stem.
at discount tire now. Tech said the yellow and red dots are a myth and not always present.
Old Dogger
Bill
Cave Creek Arizona
If the tires are, or are not defective, ROAD FORCE BALANCING will tell the story.
Discount Tire
Arizona, USA
discountti.re
All Things JEEP
Tire & Wheel Specialists
@Doublebleaaron, I'm glad to hear you are at the store to have them check the balance.
I apologize if the balance was not correct. The stores use road force balancing for all tires. Make sure you speak to the store manager just in case.
Thank you for your business.
HBDiesel
J
22 Wrangler 2018 Tundra 2018 4Runner 69 Chevelle
Lol I’m positive they are not a myth. I make discount tire line up the dots correctly and have no weights to 1/4 oz on my tires on all my vehicles. I also make them us a torque wrench. Discount tire being lazy. On my wife’s Jeep they didn’t line the spare tire dots and it have about 12 weights on the tire. Manager went out and had them pulled the spare off(only tire they didn’t line up) worker was mad about it but lined the yellow dot up to the sensor/valve stem and no weights. Yellow/red dots are not always present on cheaper tires.(that part is correct)
Doubleaaron
New Mexico
2019 Rubicon JLU
There were no dots in the tires, or they scrubbed them away
Rangemaster
Nevada
2020 JL Rubicon Diesel
Business Owner
Discount Tires
All I can say is balance beads. I am going to use them on my next rebalance on my bead locks. I have several wheels with lots of weights.
58Willys
Geoff
Western Washington
2018 JL Sport
If the balancer did not make a mistake and all that weight is really needed, then the tire has a manufacturing defect. No way I would buy a tire that requires that much balance weight.
The Last Cowboy
San Antonio, TX
2020 JL Willys 2 door
I used to work in an independent tire shop. I quit going to Discount Tire after many balancing issues and wheel damage. They work too fast, don’t re-clock the tire on the wheel if the weight is excessive and don’t care about your vehicle.
There are other tire stores out there that do a far better job. The number of weights On the OPs wheel tells me the tech was either lazy or improperly trained. Discount’s “appointments” mean nothing, as they still want you to drop it off for several hours.
roaniecowpony
Retired Engineer
Regardless of independent shop or chain shop, if you find a tire store that has good management and workers, stick with them. I found an Allen Tire Co. shop near me that has great management and workers. They get my business whenever possible.
