ESS issue
FWB FL
LArry
Fort Walton Beach Fl
2018 Wrangler JL unlimited
My ESS is inop but not complaining, but its been this way for over a month with no codes or lights on the dash, every thing showing normal in dash windows. Any one else seen this?
Dan M.
Albany NY
2020 sport (2 door)
Lucky you, I have to push the button every time. I believe there are certain circumstances where it won't activate one of which is if it is cold out and you have the heat set on a high temp. I see your in FL so that may not be the issue, but if you have the heat cranked in a month long cold spell that could be it.
WranglerMan
Will
Greenfield Indiana
2018 Wrangler JLU Sahara
There are lots of things that can make ESS inoperable, go to the ESS screen and there should be some type of message telling you why
FWB FL
LArry
No heat or air, great temps here, drove 200 miles a couple days ago , interstate, no ESS!
Ormond Beach, Florida
Retired at 55 ..
@FWB FL
You have a 2018 JL. Your warranty is for 3 yrs. and 36,000 miles. You are undoubtedly past or near the end of your warranty period.
Something is wrong. Chances are extremely high that one of both of your batteries have issues. Florida locale you live in is very hard on batteries...
With your having a 2018, and the way the 2018 handles a dead or iffy ESS battery, it is just a matter of time before you are left stranded with a no start situation.
With that said... save your energy so to speak and get your 2018 JL to the dealership Service Department, asap. Do so now while you have warranty coverage...
FWB FL
LArry
@FWB FL
I still have a little warrenty left, Last time this happen with bad batterys ever dash light went crazy along with wipers and more, I guess ill get a appt, for when I get home.
WranglerMan
Will
Greenfield Indiana
@FWB FL the FCA design of their dual battery system is sub standard at best, the ESS screen should give you some type of message on why ESS is inoperable
Here is some info from the manual, also if the ESS EVIC display advises not ready due to battery charging not a good sign and as stated if under warranty have dealer address after addressing since it’s a 2018 as stated you can have the TSB applied as @Rhinebeck01 advised and this will address the issues if the ESS battery dies and it won’t leave you stranded, there are lots of additional options one can take to address this poorly designed system once its up and going and a simple search will divulge lots of options and you have to decide what works for you.
Jeep Wrangler JL ESS issue 0130961D-D5C0-4626-B239-B2B3A65B7900
Jeep Wrangler JL ESS issue 10C1AC23-8D11-4921-AC7C-1EF32FAEBF59
Jeep Wrangler JL ESS issue 3325F379-396A-421B-813D-F2B1E467887E
Retired at 55 ..
@FWB FL
Yes, often the wipers, dash lights going crazy, etc., are what you are faced with when there are battery(2) related issues with the JL/JT..... but such telltale signs don't always exhibit themselves..
Guys mean well here, but the best advice anyone can give you.... especially, since you are near the end of your warranty period is to just go and get the JL evaluated.
Again, chances are very high you have a battery(2) related issue..... especially since you live in Florida (hot year round temps)... and since your issue has been going on for a month you say...
I know, I for one, try to avoid stealerships and usually encourage other's to do so, to do oil changes and such yourself.......but with issues related to electrical / stock batteries, most guys and gals are just better off letting the dealer address issues under warranty...
Also, as mentioned, since you probably have a 2018 (which has not had TSB 18-092-19 completed) you are at greater risk of being stranded, thanks to a bad/ depleted ESS battery and a no start situation, then a guy with a 2019 or newer JL.
