Error Code P00AF on 3.0L Turbo Diesel
RafterCExplorations
Will
Grass Valley, CA
2021 Jeep Wrangler JLU Rubicon/Diesel, 1972 "CJ-5/buggy", 2003 V8 4Runner, 2008 Dodge/Cummins 3500 w/Four Wheel Pop Up camper, 1960 Chevrolet Apache C-10, 1939 Buick Special, Honda XR650R
Then I guess they should not have rated it for 3500 lbs tow rate. And they don’t work within their “ parameters” as pointed out on this forum, overheating without towing.
If they had intended it as a regular tow vehicle, they would've upped the rating to 5000 lbs like virtually all other SUVs/medium sized trucks. Also as a Dodge/Cummins driver for the last 30 years, I know that I can't just hammer my trucks with a load over a grade and not be responsible for monitoring the critical temps AND actually backing off when they get too high. Its on me not to "over drive" the vehicle.
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
I bought this diesel jeep for the power to pull my UTV, it’s great on cool days and flat terrain but even on a cool day it will overheat pulling a grade at highway speed. I didn’t buy this to go up grades at a crawl. Very disappointed in Jeeps dismal cooling system. Yeah I know, I’ll be told to slow down blah blah. I’ve owned several diesel trucks and never had a problem. And then there’s the aux battery issue where folks are told to just put your Jeep on a charger at night. What the hell….I didn’t buy this to make up for Stellantis’s short comings.
this Jeep has turned into a love/ hate relationship.
How much does your UTV + trailer + gear weigh? Note that we don't have much headroom for additional weight when empty.
garykk
Gary
Southern NM
2022 JLURD
the trailer with UTV runs around 2500 lbs.
garykk
Gary
Southern NM
2022 JLURD
well we will have to agree to disagree. I just can’t accept making excuses for Stellantis’s piss poor designs and over rated claims, making it up to me to make up for them.
Gomer Pyle
JD
DFW Texas
2021 Sarge JLUD Willys 3.0 Ecodiesel w/SOT, Cold Weather, Alpine and Tow Pkg
the short story is Stellantis/Jeep jammed this powerplant into an engine bay that can't accomodate the proper cooling capacity. Good thing it's a dream to drive when not pushing it beyond its' limitations...
RafterCExplorations
Will
Grass Valley, CA
Seems like if it was just a "space" issue, they would have the same problem with 392; which I don't believe they do. I think part of the diesel issue the poor tuning they use in the name of emissions. They run them lean in both the attempt to keep fuel economy up, and to reduce particulate output. Not necessarily just because of tailpipe output, but because of the damage done to the motors by the EGR systems. And the generalities of modern engines are to run them lean, hot, and at higher rpms to try to keep them running "cleaner". And let's don't discount the old "planned obsolescence" argument either....
