Engine oil life problem
aretemorals
Yi
2022 Jeep Wrangler Rubicon 4xe
As @GATORB8 mentioned, knowing your build date will help determine the affect time has taken on the calculations. Look at the label on the frame inside the driver door and find the MDH code, which will tell the Month Day Hour of your build.
My 4xe arrived to the dealer 26 hours after build complete, and oil life was 98% when I picked it up. First two weeks, oil life dropped to 94%. A month later it went back up to 95%. At 5k total miles, it was at 60%. The computer needs time to learn your driving habits and adjust. You’ve only driven 73 miles in two weeks?? Get out and drive the damn thing! ?
Haha! A little busy recently, but surely I can't wait to do a road trip in the 4xe!
The build date is April 25, 2022. Would it make a bit more sense given the build date?
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
That’s probably it. Just under 3 months into the 12 month interval.
Windshieldfarmer
Randy
Wichita, Ks
2015 JKU, 2020 JlU on order
You are way overthinking this. Drive it as has been suggested, change it like Old Dogger suggested. Don’t give this another thought…. Unless you know the algorithms for the oil monitor you’re wasting valuable brain cells.
The Last Cowboy
San Antonio, TX
2020 JL Willys 2 door
The build date is April 25. What do you think? Thanks.
Nearly 3 months of time equals nearly 25% of life used, considering how little you drive it. Simple time equation.
HungryHound
Rick
TN & FL
1975 CJ-5, 1983 CJ-5, 1998 TJ, 2021 JLURe
Algorithm considers usage in the life calculation. Guy that unloaded the Jeep at the dealership drove it like he stole it.
Chupacabra
Greenville, SC
2021 JLU
It's the same as shown on the UConnect app, 76%.
Then there's nothing wrong, that's a good sign actually that they match up! I think the build date is your culprit as others have said, it's just counted off the time since build already. After next oil change and you reset it then your app should be back to 100% again, just like it is in the Jeep.
