Engine braking / compression braking difference between 4 and 6 cylinder engines?
mnforester
Andrew
Minnesota
'21 Sport Altitude
Quick question - is there a difference in compression (engine) braking between 4 and 6 cylinder engines with automatic transmission?
I rented a 4 cyclinder Sahara in Hawaii and tried using compression braking coming down from a volcano and I had to ride the brake in 2H, 4H, and even 4L (in manual first gear). Wondering if my 6 cylinder will do better on steep grades.
Thoughts?
Jeep Wrangler JL Engine braking / compression braking difference between 4 and 6 cylinder engines? 3C65D872-3CA0-458E-B045-8A7BD44F4106
Dan M.
Albany NY
2020 sport (2 door)
I have a 3.6 and my wife has a small displacement engine in her Chevy equinox. I believe larger engines provide more resistance when engine braking as larger engines have more mass and it takes more energy to move the internals. Probably explaining this wrong, hope you know what I mean.
No IFS
So Cal
JL Rubicon
I can tell you that the compression braking on my 3.6’s incredible. The auto transmission in combination with the compression braking it’s the best driving vehicle I’ve ever owned.
AlgUSF
Melbourne, FL
2021 JLUS, 2014 Tundra, 2013 Odyssey, 2002 Civic
Try it with the 6MT, it seems my manual transmission vehicles keep rotors forever.
Some Random Guy
Washington
Comptroller
Does the I4 have a lower cylinder compression? If so would that reduce the amount of braking it can apply in addition to the lower displacement? I thought turbo engines usually had lower compression so the turbo can ram more air in there, but I’m not an engine person.
AlgUSF
Melbourne, FL
More engine braking -- shift down
Less engine braking -- shift up
Leave it in D and you get little drag from the engine because it'll leave the transmission in overdrive.
When I take my Tundra to the mountains, I'm always in 'S' and dropping a few gears on the downhills. Our odyssey doesn't have that option, so I just hit the 'D3' button and use the brakes more often. When I take our manual transmissions, I wind them out in low gears. My Jeep could use a 'Jake Brake'. :)
mnforester
mnforester
Andrew
Minnesota
'21 Sport Altitude
Great to hear. Do you have a Sport, Willys, or Rubicon?
mnforester
mnforester
Andrew
Minnesota
'21 Sport Altitude
Thanks all for the thoughts. Living in flat Minneapolis means that I'll have to travel up to the North Shore of Lake Superior to find some decent long grades to see if my auto V6 compression brakes better than the 4 banger. It can't do worse because that 4 cylinder was pretty terrible.
Petey
Pete
Miami
2020 jl sport manual
4T has lower compression apart from that 3.6 has more cylinders a difference should be felt.. an engine person would be a good character name on the rick and morty cartoon.
Upnarms
AZ
2019 JLUR, 2003 TJ X
No experience with the 2.0 other than when I had a loaner. But I can say in 4L in my rubi 3.6, if i place the auto in manual mode, 1st gear brakes big time... Was a crawl down shafer trail. If i left in auto mode it would end up in 8th quickly with not much engine brake.
J0E
J0e
Hawaii, MT, SLC, NYC
bt39.com
2021 JLR, 05 LJR on 43s
The 6 has 2 more cylinders and higher compression so I'd predict more compression breaking potential, over 50% more. Never tested my assertion.
Where were you in 4H? what was your RPM and gear?
I come off the volcano in my JLR 2.0T with auto, M shifting, 37's, & stock gears with minimal brake input.
Where were you in 4L? what was your RPM in M1 that you needed to ride the brake?
With the Ruby 4.10 diffs, 4:1 xfer case & stock 33's, M1 in 4L rarely required brakes (dropping off ledges obviously does). But with same gearing on my 37's, I need breaking more often.
I much prefer the 2.0T, extra bonus at altitude. I burn half the fuel the JK & JL 3.6s burn on the trail, but much of that is my aggressive use of MSS (Manual SS).
mnforester
mnforester
Andrew
Minnesota
'21 Sport Altitude
Hey thanks for the comments. Yes, tried 2H, 4H, and then 4L using manual gears. None could keep me from rolling faster and faster and RPMs went too high for my liking. I don't recall what the RPMs were - but clearly going too high.
I also believe that your Rubicon gearing vs my Sport S gearing will also make a difference. I hope my Wrangler can engine brake enough to make trail running in Rockies enjoyable. I'll try to find some steep slopes here in Minnesota to test out capabilities.
blnewt
New Mexico
Just ask @cosine he knows!
You can also use hill descent in 4Lo and not even worry about brakes (or I should say "applying" your brakes, let the computer do it for you :)
