CopperMtnGuy
Installed the Dynatrac 2" Endurosport lift this weekend. Quadratec showed a 5-6 week back order and Northridge showed it as discontinued, so I ordered it and it showed up 3 days later, so that was awesome. Install went smooth, loosened all the control arms front and rear and retorqued on the ground. Only issue was that the bolts for the new rear sway bar end links/bolts were bigger than factory, so had to drill out the factory rear sway bar a little bit. Wasn't planning on the lift coming till April/May, so I didn't order longer front LCAs or new track bars, but at this point I'm not sure I will. Rides so much nicer than stock. Flexes good with the rubicon sway bar disco too. Put about 80 miles on it. Forgot to measure before, but feels probably 2.5-3" higher than stock, I must have been sagged out before. The tires don't look as small as I expected, but will upsize when these wear down!
