Dynatrac EnduroSport 2" lift...what to expect?
JLAFAKASI
Lito
Richmond, VA
JlU Sport S 2019
If it’s worth anything...I beat on mine daily and then drive it home. Of course it’s not meant for the double blacks, but it’s a nice drive home.
you still running stock axles? Also did you regear and what size tire and rim off set here?
longleaf_JL
Lance
North Carolina
2019 Jeep JLU Sport, Dynatrac 2” lift
Retired Veteran
I ran stock axle for a long time but have replace them with Rubi axles. I have KMC Machetes which have a 3.5” back spacing with 40” NITTOs
JLAFAKASI
Lito
Richmond, VA
JlU Sport S 2019
Sweeet! Still on the enduro sport I’m assuming suspension and, what gears would you recommend for 35? 4.10 or 4.56? I dail drive a lot and currently run 3.45 stock for beach and fire trails which seem to be fine with 33s on my sport jlus
longleaf_JL
Lance
North Carolina
Retired Veteran
Everyone has an opinion on gears...I will just tell you after I installed the Rubi axles I ran 37s for awhile with the stock 4.10s and everything was fine. The 8 spd really is the difference maker in my opinion. So with 35s if you feel like you need to re-gear that’s where I would go...but with the cost of the re gear you might be able to find the replacement Rubi axles with a locker for not much more. Which would be better in the long run. I just threw on a Barnes 4WD truss system which protectS the same as Artec and is cheaper. And still USA made in NC. And at the end of the day it how you drive it.
JLUin818
San Fernando Valley
2018 JLU
i installed the dynatrac lift with .5" spacers all around. do i need to add an adjustable track bar? have you Dynatrac owners installed one? does the .5" spacer make a difference for needing one?
D&C Designs
