Bswen
There is a thread I read here that explains an easier way. I think someone got a longer bolt and threaded it into the door jam them just opened the door until the check was pulled back out. Then they went back to the regular bolt??? I think...Thanks for all the advise! We took the long trip, and worked great as stated without bolts. The door check was another issue...
I tried "pushing" these into the passenger door and discovered it is under quite a bit of tension for those looking to do it. Its able to be done, but goes in with a pretty big effort and thunk. (almost made me think I broke it/something) Needed 2 people too. One to hold door and other to push in. (no further extrapolation on nut jokes there...) ;]
I then decided I didn't want to do that on the passenger side figuring the wife would forget and just swing wide open. (I know old JKs didn't have but the strap, and normal, but not all wives created the same... ;]
So I went to pulling the door checks out of the door and that was definitely a larger endeavor... Ended up with some pliers, a pry bar and some cardboard to protect paint and 2 people again!
There has to be a better way!? Any best practices people have found out there to push and pull door checks out of door simpler noting they are under pretty fair tension?
