Reset abs without driving?
ahmadtaha1988
ahmad
dubai
2023 JL 4 door Sahara
When driving is the desert I remove the ABS fuse (I actually imulate that with a switch and relay). The onboard traction kill is not enough even with long press. BLD seems to kick in and make the car less capable.
There are situations however when I can be stuck in a bad position and BLD would be nice to have. I see the rubicons with an actual locking diff able to get out of them (I have Sahara). In theory BLD should give a somewhat similar performance, the problem is it does not work cause of my kill switch....
I could flip it on, but abs light and traction control light stay on and BLD stays dead till vehicle drives a few miles.. kind of hard to do when you are stuck in sand .. so I end up needing to be pulled
Any ideas for some trick to get the abs, traction control, and bld to come back to life without driving
