alphawolff
- Jul 31, 2023
- california
- 2021 JLU
I just use apple maps, they seem to work great
But my destination is set in Apple Maps using CarPlay.![]()
I paused the OPs video and this is what's popping up. It seems like it's trying to reroute or give directions, but has no idea what to do since there is no destination.
Your AI girlfriend is pissed off, you won't tell her where you're going.
Also why are you driving around in 4HAuto?
try a different phoneBut my destination is set in Apple Maps using CarPlay.
mine certainly doesn’t
Good luck. Most dealers can’t troubleshoot their way out of a cardboard box.I have used many phones, many cables, wireless etc. It has been happening for two years. working with jeep on fixing. they are still trying to figure out which part is the cause.
They have replaced my cluster display but it didn't fix it. Radio on order to see if that is it. I will pop back in and let you know if that fixes it.I have this exact issue in my 24. If I disable nav directions in the DIC, the flashing problem goes away. However, the option turns itself back on and then the flashing happens again.
On the 4xe, if you want maximum performance you must be in 4HI Auto. This is a full time AWD mode with automatic clutch based engagement of the front axle.But why were you driving around in 4 high? lol
Yes, I have the same T case. I didn't realize it was a performance thing with the 4Xe. My mileage takes a reasonable hit when I use 4 auto in my JLUR.On the 4xe, if you want maximum performance you must be in 4HI Auto. This is a full time AWD mode with automatic clutch based engagement of the front axle.
If you are in 2HI, you will have significant performance penalties.
When I had my 4xe that was the mode I drove in exclusively while on pavement. When on dirt it was 4HI Part or 4LO.
With my MOAB, I have no option, it is 4HI Auto with no provision for 2HI. I am just fine with that.
You couldn't just give me aBut why were you driving around in 4 high? lol
