Door Hinge Steps
turk
turk
Turk
Goulais River Ontario
JLUR BW
Industrial HVAC Supervisor
I'm going to try your washer trick. but I'm also going to add 2 rubber cone washers I found from a toilet repair kit under them to fully fill the cone shaped void in the door hinge before I tighten it all down
jeremyjeep
Jeremy
Jeep, USA
JLUR
YOKiN
Jason
'65 Impala SS, BMW X5M, 2018 Wrangler JLUR
Military
That's a really good idea about the rubber parts to fill the void. I actually just picked up more washers. I doubled them up and was able to torque to specs. I couldn't find any rubber cone pieces..I almost went to the toilet section though lol. 4 bags of these did the trick.
Jeep Wrangler JL Door Hinge Steps 20180418_180340
TIDALWAVE
CHUCK
MINNESOTA
2015 Mustang GT Convertible, 2013 CHEVY SILVERADO, 2018 JLUR
I would use stainless washers or better yet synthetic washers to fill the gaps. Remember your doors are aluminum and it loves to react with steel, even if it's galvanized steel. Ford uses composite layers to separate steel from aluminum in its F150 pickup.
turk
turk
Turk
JLUR BW
nicely done. I also didnt have enough of those flat washers. but I did find these at home depot. I had to cut them down. but now I'm thinking I should paint the steel washers with black rust paint so they dont rust and leave water streaks down my door paint. and I'm going to get the 3/8" rubber version of these washers to see if it's an even tighter fit...and yes in the toilet section
Jeep Wrangler JL Door Hinge Steps shopping
KCVS
Kevin
Chicago
Acura and JLUR in KZ
They help with loading and unloading from your roof. I can't speak for Yokin but I kayak and these are a huge help when loading my 'yak. That way you aren't trying to balance on your door sill. Much more stability. Oh, and it looks cool.
Just figured out how to load mine without a ladder. Still going to go with domething that can have a hullivator mounted once available.
matto
matt
South Texas
Jeep JKR 2008, Jeep JLUR
Damn why didn't I think of washers!!! I reshaped the bracket to fit inside the curves and took forever and a day!
Mailmanj4
Oregon
2018 JLU Rubicon
I was thinking of trying that. Did you gave to grind the corners? Any trouble getting the bolts off? I am having a heck of a time getting them loose. Using a T45. Is that what you guys have used?
YOKiN
Jason
Military
T50.. whatever the instructions said lol. Don't worry about the paint. You're going to use the longer provided bolts anyway.
YOKiN
Jason
Military
Yeah. That sounds like it took awhile. I bet it looks good though. I'm going to get rid of the gasket it came with and just use a silicone bead for a cleaner look.
JL1LE
Neal
Denver, CO
2018 JLU White Rubicon
Looking to go the same route as others here. Can somebody provide a picture with the door steps installed in their JL, from far away?
