Door ajar switch stopped working
Sean.Lunch
Sean
Charlottesville, VA
2019 JL Unlimited Sport S
I have a 2019 JLUS and I’ve just realized that my Jeep does not know when the drivers side rear door is opened. The window and lock still work, but the dome light won’t trigger for that door. Does anyone know where the door ajar switch is located? I suspect it’s built into the latch mechanism assembly, but was hoping to get confirmation before i buy the replacement part and pull the door apart.
thanks!
Sean.Lunch
Sean.Lunch
Sean
Charlottesville, VA
I realize I may have posted this at a time that not a lot of people were on the forum. Does anyone know exactly how the JL’s know that a door is open? I can’t find any part number for a separate door ajar switch. So is it in the latch mechanism?
Rhinebeck01
Ormond Beach, Florida
Retired at 55 ..
@Sean.Lunch
Have you had the driver's door off and it's associated driver's door harness disconnected?
...IF so, you undoubtedly bent a connector pin when you re-attached the harness.
Harness can be disconnected like last time..... then you carefully bend the pin(s) back straight and then carefully and with proper technique reconnect the door harness.... and all should work aok then..
Sean.Lunch
Sean.Lunch
Sean
Charlottesville, VA
@Sean.Lunch
nope, haven’t had the rear doors off since last year
Sean.Lunch
Sean.Lunch
Sean
Charlottesville, VA
I looked at the wiring diagrams available on the forums and found that the door ajar sensor is part of the latch mechanism. So I bought a new latch mechanism back in June and haven’t had a chance to install it yet. Been traveling a lot for work in the second half of the year. Probably won’t have time until after Christmas.
AcesandEights
Aces
So. Oregon
2024 Toyota 4Runner
When is a door not a door?
Altitude2020
Canada
2020 Jeep Wrangler JLU Altitude
I had the latch replaced in May and I still have the issue. All pins and connectors where checked. Dealership is taking the car in for a week in January to see of they can fund the issue. I have the extended warranty.
AcesandEights
Aces
So. Oregon
2024 Toyota 4Runner
...when it's a jar.
mwilk012
Oklahoma
2018 Ocean Blue JLU Rubicon
Service
Same door latch quit working on mine. Repair part is cheap, repair sucks though. You'll need a very long torx bit to remove the door handle from the carrier plate assembly. I can't remember the size right now but there are some good youtube videos of it.
Sean.Lunch
Sean.Lunch
Sean
Charlottesville, VA
Keep us updated on what the fix ends up being. You’ve got me a little scared that it’s the wiring harness. Easy enough to check continuity on some wires but that repair would suck.
Sean.Lunch
Sean.Lunch
Sean
Charlottesville, VA
I forgot to mention - my Jeep is at the paint shop until Christmas having its corrosion on the doors and hood corrected. So I couldn’t fix the door ajar issue right now even if I wanted to lol. 84 hours of labor…. Luckily still under the corrosion warranty.
Altitude2020
Canada
Yuup, doing the corrosion warranty in April. Not to impressed with the JL.
kenerg
Kevin
Hudson NH
2018 JLU Rubicon
I am having the same issue. I have only had the doors off to be repainted. ( 3x Welcome to New Hampshire ). Does anyone have the part number for the latch mechanism? Its preventing me from using the Auto start and its kind of important here in the North East!
Altitude2020
Canada
It's
I got the sensor replaced under warranty. Try that route.
