Front passenger door lock stopped working
AC77
AC Abegian
Los Angeles
Autobody , singer-songwriter
Hey everyone. Just noticed the front passenger door lock stopped working
All 3 doors lock and unlock
When outside the car with key in hand/pocket the passive entry works (the door handle button-touch ). But won’t unlock
The front pass.door locks and unlocks manually
took it apart. Checked everything. Even bought a new OEM door latch. Plugged it in and still the same
to my best knowledge. Current is going through the pins and at the disconnect plug in the footwell.
triple checked for any bent pins. All checked out good
Found one 40A fuse (under hood) it said pwr drl. Assuming it’s for power door locks. Removed it and it’s fine not blown
before I call the dealer which will be a long wait and I hate anyone touching my car if I don’t Know them personally
Anyone out there run into this bs ?
Tnx in advance.
NJJeep Guy
New Hampshire
2020 Hella Yella JLU
If you have already checked the wiring harness it is time to make it Jeep's problem. That's what your warranty is for
DaltonGang
Doesn't Play Well With Others
It could be an issue with the programming. These things are overly complicated. If it were me, doing what you are doing, I would disconnect the batteries for about 15 minutes, to reset everything. If that fails to work, then off to the dealership for some warranty work.
AC77
AC77
AC Abegian
Los Angeles
i highly doubt it’s programing I will scan it with my Autel Tomrrow at the shop. If all fails I will call the dealer. Which I don’t trust them at all
