Does this sound like an okay 3.6?
ajbarbier
AJ
2018 Jeep Wrangler Sport S, 3.6
Just double checking before the 3 month CPO fix-your-sh!t warranty runs out, does this sound healthy and normal?
DaltonGang
Doesn't Play Well With Others
Sounds like typical noisy injectors.
ajbarbier
AJ
Perfect, no worries there then? Even on the right hand side near the end?
The Last Cowboy
San Antonio, TX
2020 JL Willys 2 door
That's what they sound like. Use 0w30 or 5w30 next oil change at it will calm down slightly.
roaniecowpony
Retired Engineer
Diagnosing an engine by sound is often difficult when actually there with the engine. Doing it over the internet is another layer of muting of high freq metallic noise. So, no. I don't hear anything the causes alarm.
IndyTom
Thomas
North Myrtle Beach, South Carolina
2024 Jeep Wrangler Willys JL 4 Door, 2026 Tesla Model Y Juniper
Sounds Fine . Use whatever Oil you like as long as it is a Full Synthetic. I prefer Valvoline Restore and Protect in either 0W20 or 5W30. I used both on separate oil changes and found no real difference in sound or gas mileage. If you warranty is at an end use the 5W30 if you are under factory warranty use 0w20 otherwise they can refuse your warranty claim.
azjl#3
North AZ
Maybe give more than 27 minutes for a response then?
Sounds fine
