Does recirculate actually work? JLUR
rubydoo
KS
18 JLUR
I have about 2k miles on my JLUR. I noticed that even with recirculate on, I can smell things from outside. My others cars all kept the outside air out enough that I couldn't smell things from outside. (like a smoker in front of me, the strong smelling foam at a car wash, etc). This probably isn't an issue for most people but I have really bad allergies and I can't roll my windows down or use vent without being miserable at work all day, so I use AC and recirculate. But since I can smell things from the outside I feel like it's not completely sealing or something.
Has anyone else noticed this or is this just normal for a jeep?
dangerz
Roy
Fort Worth, TX
JLU Sport S
A Jeep isn't exactly the most insulated vehicle.. I'm assuming you at least have a hard top?
WranglerMan
Will
Greenfield Indiana
2018 Wrangler JLU Sahara
I have a 3-piece freedom top that has not been off yet and notice no outside smell with recirc on but can tell when it’s off
bodam
Bob
Cypress, TX
2018 Jeep Wrangler
I agree the recirculate kinda sucks, but if you don't want the outside coming in, why in the world did you buy a jeep?!?
Jeepsterfreak
Honda, Future JLU
Make sure Jeep actually installed air cabin filters behind the glove box. That might help some.
Krondor
Here, but soon there
2018 Punk'n Jeep Wrangler JLR
Look to see if your cabin filter is installed. Even still, you may need to find a carbon replacement filter.
The carbon filters work better to remove oder.
Fuel Fire Desire
Michigan
2018 JLU Sport S, 2020 JT Sport
I tap recirculate overtime I pass by a big Marathon refinery nearby when Im down wind. I don't notice any more odor than I did on my last two vehicles in the area (a Challenger and Camaro).
Going by a local beef farm (where they ferment manure for fertilizer) I still get odor inside, but I also have with every other car Ive owned. That cloud of rancid BS is thick.
modeltrainman
Robert
Chicago
2013 jku rubi
When the recirc button is pushed you should here the way the blower motor sounds change ,as it is now drawing air from the inside versus outside,try running the blower on full and listen as you push recirc then change it back to outside air.And if you dont really hear a difference you could always take it in and have it scanned the recirc motor is a actuator so if its not working it should set a code.
rubydoo
KS
18 JLUR
What's weird is that on non-resirculate mode (or vent mode if you'd rather), the air even on the lowest fan setting blows REALLY hard. Is that normal for a wrangler? I guess it could be the nearly vertical windshield giving great pressure for air intake. (hvac intake vent is usually base of windshield in most cars) If that's NOT normal, maybe mine's missing a part or broken or something. Vent mode on lowest fan setting blows air harder at highway speed than recirculate mode with fan on full blast. Vent mode in every other car I've owned is usually pretty weak compared to this
VinnyV2
seattle wa
JL Rubicon 6 speed
My recirc works well enough to keep all the car wash tunnel smells completely outside the rig, you must have something wrong.
