DIY Tailgate Table
rustyshakelford
Brett
Navasota, TX
2019 JLUR-8 speed 2020 F-350
I have an outback adventures one I'm trying to sell but man the shipping cost is kinda high. If anyone is in South Texas I'd sell it for 275. Its almost brand new.
wish you were closer. We’re trying like heck to find a tailgate table in preparations for our big trip and nobody has any in stock
brett
Maverick909
I.E.
found my next project. been wanting a table but i cannot find the reasoning behind 200-300 bucks. might start getting parts to work on this next week.
Tahoma
Norcal
2019 Jeep Moab
Doesn’t take long at all...just some wood cutting and you’re good
Maverick909
I.E.
i agree. couple cuts. and maybe a couple drink spots and it will be good to go. i like that it sits tighter to the rear door than most too. dont wanna loose to much room in the small cargo space..
nositting
PA
19 JLUS
Just thought I’d share the final product. Pic in Zion
many pay the money for the nice slide out cutting surface. something like that could easily be added to what the OP did (or not).
this looks nice!
IQ_imbalance
Bob
Maryland
2022 JLU Rubicon 3.0d
I made one and it worked well. I used a 1/4in plywood sandwiched with a nice 1/4in black HDPE sheet.
I used these shelf brackets and just flipped them upside down.
https://www.amazon.com/Folding-Shelf-Bracket-330lbs-release/dp/B06XBWCQB5
If you pull off the plastic cover on the tailgate, there is a set of empty bolt holes that take M6, if i remember correctly and just bolt the hinges in to that, but get long enough ones so they can reach through the plastic cover.
Blast from the past, but do you have photos? I’m brainstorming how to use the M6 bolt holes to my advantage but no need to recreate the wheel!
I’m also thinking about setting it up so the board is easily removed to be used as a jack platform for sand or soft ground…..
stingGreyNJ
NJ
2018 JL Rubicon, 2013 JK (gone)
Did you paint the tailgate plastic to match the tan seats or does it come like that now?
My DIY $35 drop down table. It is all available at Lowe's.
stingGreyNJ
NJ
That's fantastic. Really well done and unique to those that know but looks so clean and OEM to those that don't know.
I Krylon Plastic Fusion rattled canned much the upper interior. Too much black IMO. There are a couple photos my showcase...https://www.jlwranglerforums.com/forum/showcase/biscuit.1163/
MPTee
Pacific North Wet
Jeep - "nuff said
A re-post I did on the "Best table " thread, then saw this DIY thread that seemed more appropriate.
I just finished a DIY table from scraps laying around the shop - I spent a total of $1.36 for 5 screws. All else was "free". However - if I were to have been paid $2.00 an hour for engineering and fabrication time - it'd have been much cheaper to buy one.
That being said, here is my "do-all" table. 28" wide, 22" deep, with a 16" deep top shelf. Everything is hinged, so I can use either half table or whole table, top or bottom, as I see fit. The whole thing weighs 14 pounds and sits less than 2" deep when closed (including the 0.200" offset from the tailgate for venting). Made out of 0.062 aluminum.
I like the KISS theory, but always seem to fall into the KICD clan (Keep It Complicated Dipwad).
Jeep Wrangler JL DIY Tailgate Table table closed
Jeep Wrangler JL DIY Tailgate Table table open
Jeep Wrangler JL DIY Tailgate Table table 2
Jeep Wrangler JL DIY Tailgate Table table 3
Jeep Wrangler JL DIY Tailgate Table table 4
Pinion
Rob
Hull, MA
1971 FJ40, 22 Rubicon Unlimited
Project Manager
That's pretty slick
MPTee
Pacific North Wet
Jeep - "nuff said
Thank you Sir. It turned out better (and bigger) than I expected.
