Disable Triple Honk
wmfertig
Wanda
Lutz, FL
2018 JLU Rubicon, 2024 JLU Rubicon X
On the 2024 Wrangler, is there a way to disable the triple honk when the vehicle is running and the key fob exits the vehicle?
Powelligator
Parker, CO
2006 LJ Rubicon, 2022 JL Rubicon
Aftermarket. Tazer, a device that stays plugged in under the dash can disable the three honk “feature”. Does a lot of other things as well, like correcting the speedometer for larger tires, etc.
wmfertig
wmfertig
Wanda
Lutz, FL
Thanks so much! After further searching, this seems to be the only remedy. I appreciate your reply!
dragoneggs
Seabeck, WA
'22 Snazzberry Pearl JLR
I have the Tazer. Works great. Difficult interface to program though. You will need to have the instructions in front of you when you use it.
Make sure you also buy the ‘extension cord’. It is a real bitch to unplug/plug in if you don’t. The first time you have to pull the connectors, I guarantee you will be cussing.
wmfertig
wmfertig
Wanda
Lutz, FL
Thank you for the heads-up! I appreciate your reply.
dstevens
CA
2024 JLURX
I do not believe the tazer disables the triple honk on the 2024. When I get a chance I'll test it, but there are many bugs with the tazer on the 2024. I'm fairly sure that sway bar disconnect, auto park, tire fill, traction control memory, triple honk features do not work. Menu display doesn't work very well either. ESS, cooldown, winch mode, turn assist all work. Other features I never used.
wmfertig
wmfertig
Wanda
Lutz, FL
Oh wow! Good to know. I look forward to hearing what you find out, and I'll do some more searching as well...
Grey24Rubi
NW
2024 4dr Rubicon
Has anyone talked to their dealer to see if they have a scan tool of some type that'll turn it off? That triple honk thing is annoying as hell!
autotragic
the cornbelt
'21 JLR 6MT
Yeah the taser you really want one anyway but they need to do another update for the 2024s. I know on mine I can't live without the taser it just does so much. Killed three honk, have steering wheel shortcuts for front sway bar disconnect and lockers I mean just all kinds of little quality of life improvements.
rickinAZ
Rick
Phoenix
2026 MOAB 392
On the 2024 Wrangler, is there a way to disable the triple honk when the key fob exits the vehicle?
Mine doesn't do that, and I don't have a Tasar. I get a single (programmable) beep when I lock the Jeep, but no sound for merely exiting the vehicle with the fob in my pocket. What am I missing?
dragoneggs
Seabeck, WA
The 3 honks is when you leave the key fob in the vehicle.
rickinAZ
Rick
Phoenix
2026 MOAB 392
Oh. Mine does that. But...only if I try to lock the jeep with the fob inside. The OP's question was "On the 2024 Wrangler, is there a way to disable the triple honk when the key fob EXITS the vehicle?"
rohdawg
Long Island, New York
Merchant Marine
I get three honks if the Jeep is running and I have the fob with me leaving the vehicle.
Killed that with the Tazer and mine is a ‘24
JesseT
PNW
'24 4xe
Mine does it if the key fob exits the vehicle while it's running and the door closes fully.
wmfertig
wmfertig
Wanda
Lutz, FL
Specifically, it honks three times when *the vehicle is running* and the fob exits the vehicle.
