Diff covers
5280Sapper
Saratoga Springs, Utah
2018 JLU Rubicon
Disabled Veteran
WXman
Central Kentucky
Just curious...why do you want a diff cover?
The stock axles already have fill AND drain plugs, which is very nice. And as far as fluid temps go...additional fluid doesn't cool an axle. It just makes it take a little longer for the fluid to reach max temp, and a little longer for it to cool off afterward.
Now, an inexpensive skid plate to protect the stock cover from rock damage, I can see that being a nice thing for guys who crawl rocks a lot. But I don't see any advantage to an overpriced aftermarket diff. cover.
5280Sapper
5280Sapper
2018 JLU Rubicon
Disabled Veteran
The purpose is because they oem covers are stamped steel they can bend up on the lips and sent and even be penetrated by sharp objects, and damage the ring gear of differential, So then you’d be screwed on a trail! After market ones are thicker and likely you’d never hurt it or what it’s protecting.
Jeepsk8
Sierra Vista, AZ
2020 JLUR
You lose some clearance with skids as well. A good set of nodular diff covers will save your bacon when crawling on rocks. Is the diff a different shape than the previous Dana 44's? JK covers won't fit?
TTEChris
Houston, TX
www.tankcustoms.com
2021 JTD & 2021 4XE
5280Sapper
5280Sapper
2018 JLU Rubicon
Disabled Veteran
Yes this new gen 3 advantek Dana 44 is different. Motobilt, afe, and the other company who is a vendor on here are the only ones I know of who make them so far.
Jeepsk8
Sierra Vista, AZ
2020 JLUR
Just perused the Spicer brochure. Ring gear is smaller but the pinion is much larger. Stands to reason the housing will be different. $150 for the Spicer front cover, sheeze!
Jeepsk8
Sierra Vista, AZ
2020 JLUR
Motobilt looks promising for price, AFE no effing way. Who is the vendor that is on here?
NVM, I found them. Next Venture. $200 for the front bare. Uggh.
NextDan
Peak Sponsor (Level 2)
Grand Junction , Colorado
www.nextventuremotorsports.com
1949 Willys VJ, 1973 Jeep Commando, 18 JL , 21 JT
CAD Designer, Adventure Machine Outfitter
Just wanted to include that they are ~$170 if are using our JLWF Discount code ;)
TroyBoy
Troy
Vancouver Island, Canada
Doh! I forgot about that when I ordered mine. :(
NextDan
