Diesel front grille inserts question
Steve949
Orange County, CA
2020 JLU Sahara
Noob question: I understand that the diesel JL is supposed to have grille inserts with large openings, like the JT. My 2020 diesel JLU has the small openings in the grille. Anyonw have any idea whether I should make the dealer change them out? Or am I ok the way it is?
Dyolfknip74
Ottawa, Ontario, Canada
2021 JLU Rubicon
Does the current set up bother you? Ostensibly you've had it for at least a year and you're just deciding that a grill opening is a big deal? Please, keep us informed as to what the dealer says.
TX_Ovrlnd
CStat, TX
'22 Zilver JLURD
freethinker
Noob question: I understand that the diesel JL is supposed to have grille inserts with large openings, like the JT. My 2020 diesel JLU has the small openings in the grille. Anyone have any idea whether I should make the dealer change them out? Or am I ok the way it is?
Are the 2021 and on JL's coming with JT grille inserts? I thought you had to have the front camera to get them. I don't think you can get the dealer to add them in free of charge, shouldn't be too expensive to change out yourself though.
BDinTX
Dallas, Tx
Interesting situation for sure, I'd think the smaller grid openings would be ok where your temps are pretty mild as long as you're not towing heavy. I'd be more concerned if you were somewhere hotter like Southern Arizona.
Jeep Wrangler JL Diesel front grille inserts question 1639574481892
Jeep Wrangler JL Diesel front grille inserts question 1639574517220
Jeep Wrangler JL Diesel front grille inserts question 1639574383499
Jeep Wrangler JL Diesel front grille inserts question 1639574606312
BDinTX
Dallas, Tx
Looks like it would be about $150 to swap them out if you can find them in stock.
6QN23RXFAB - Left Side Honeycomb Grille Insert
6QN21RXFAB - Right Side Honeycomb Grille Insert
6QN22RXFAB - Center Honeycomb Grille Insert (For Vehicles WITHOUT Front Off-Road Camera)
or
6QN24RXFAC - Center Honeycomb Grille Insert (For Vehicles With Front Off-Road Camera)
Come2elmo
South Texas
07 Chev 2500 HD, 16 Chevy Burb
my 21 without front cam has the smaller grill openings
TX_Ovrlnd
CStat, TX
'22 Zilver JLURD
freethinker
I had gone back and forth on ordering mine with the camera vs without just for the guarantee of the inserts, thinking I'd use the hood lock more than the camera though.
CWRUYOTE
CLE
2021 JLURD
I have the Bolt hood lock; the middle section (small honeycombs) comes with the lock. I figured if I bought the middle section with the large honeycombs I'd just butcher the whole thing to enlarge an opening for the lock, so I just left it.
So, I have a sort-of hybrid look. It wasn't really that hot here in OH this summer and I didn't see much of a temperature difference when I went on long road trips or when wheeling this summer as well, so YMMV.
Jeep Wrangler JL Diesel front grille inserts question IMG_3900
Steve949
Steve949
Orange County, CA
2020 JLU Sahara
Where did you get that lock?
Steve949
Steve949
Orange County, CA
2020 JLU Sahara
Thanks everyone for the responses. It doesn't bother me the way it is, so I'll probably leave it. I didn't even know about the difference until I was looking at installing the front camera made by the Tazer people. It said the diesel and electric JL need the camera designed for the JT because of the larger grill openings. But mine aren't. That's what brought up the question.
blink9cd
Billy
Virginia
'21 JLU Willys
FYI I just did the switch to the JT honeycombs today. It's super easy to follow the Bolt instructions to cut the one section out for the hood lock. No chance of you screwing it up
Jeep Wrangler JL Diesel front grille inserts question IMG_4298
Instructions are here: https://www.boltlock.com/application/files/4615/8740/1200/JT_Hood_Lock_Grille_Template_Gladiator.pdf
AC77
AC Abegian
Los Angeles
Autobody , singer-songwriter
that's unique imo
