It was an option on mine. I think it was $85 when I got my 2021, but around $100 seems right.Does anyone know if the heater is included as standard equipment with the ecodiesel? I have seen no mention of it in the build guide. Wondering if it is available anymore.
From what I've been told, is using a block heater helps prolong the life of the diesel engine too, let alone the draw on the battery in cold temps.Yeah, there was no secret for the 2021 models. Thanks for your input @GearWhore and @brewski
Must seem insignificant to Stellantis not to make mention of its existence. Salesman and manager had no more info than me. We often see below 0-F during our winters so it matters to me.
I found this situation interesting and looked to get you info.Yeah, there was no secret for the 2021 models. Thanks for your input @GearWhore and @brewski
If you're looking to see if you have the block heater I think the best angle to check is from underneath. This is what it looks like, my brass fitting (pic above) had no threads so I suspect it has to be removed to install the heater.Unless someone else chimes in, I'll pop the hood this afternoon and take a look.
